I'm hoping someone who got the sk group buy springs can clear something up for me.
I have read through the suspension thread and of the "STAGEA SPECIFIC" whiteline springs,
but the part no's mentioned by SK are 83159(front) and 70191(rear) and are R33 GTR, R32 GTS according to the whiteline catalogue.
Are there STAGEA specific springs or are they the same as the skyline.
cheers
g
https://www.sau.com.au/forums/topic/255857-stagea-springs/
i was told by matt they were 34gtt/gtr front, 32gtr rear...
Tein make a similar rate spring designed for the stagea, not just 'made to fit', and can be found through access autoworks, a sponser on here, for similar money.
https://www.sau.com.au/forums/topic/255857-stagea-springs/#findComment-4412737
You can go to any good suspension shop and order springs to your desired height / diameter / weight. I researched my spring choice carefully for my car before buying a set of Eibach off the shelf springs as the ones in the SK kit sounded a bit soft for my liking 4kg from memory. FYI the spring rates for the C34 Nismo kit from memory are 6.9kg front and 6.9kg rear. I got a set of Eibachs of the same weight they were around $280 a pair so for around $600 you could get a front and rear set.
Also don't buy tein unless you are forking out heaps of dough on the top shelf stuff I have only ever heard bad thing about them. If you are considering a set of coilovers then look at the Greddy coilovers I reckon they are just about the best you can get for the money, they ride really nice and are what I have fitted.
https://www.sau.com.au/forums/topic/255857-stagea-springs/#findComment-4412865
The Eibachs sound cool- I have some on our BMW.
Do you have part numbers and where did you get them from?
$600 front and back sounds reasonable. How lowered from standard are they?
https://www.sau.com.au/forums/topic/255857-stagea-springs/#findComment-4413252
Hi one of the girl`s here has done this & i think she paid less then $600 & it shouldn`t be that much for 4 spring`s really ,so make be look at what`s about a bit more you may find something,cheer`s chuckie.
https://www.sau.com.au/forums/topic/255857-stagea-springs/#findComment-4413285
I have had a hunt and I managed to find the box I had for the rear springs. The number on the sticker is 1000.250.0450 which translates as Free Length 1000, Inside Diameter 250.00, Rate 450 lbs/inch. The fronts are different but I am not sure what they are exactly. In terms of lowering I am not sure how they would go being fitted to a set of standard shocks. I have coilovers with adjustable spring seats and lower mounts, this way i can retain as much traval as I like and also have the car lowered to a reasonable height without it bottoming out.
I dealt with Trutrack suspension in Melbourne they are really good to deal with they stock Bilstein and Eibach stuff and can easily recommend something.
https://www.sau.com.au/forums/topic/255857-stagea-springs/#findComment-4413404
My teins cost $300 for four. My height is determined by the settings on the Bilsteins - lowered about 35mm
ps I am not saying to get teins ..mine are a bit on the hard side... but they were not expensive. If your car hasn't done too many Km you could try just getting the Bilsteins and change the springs later if necessary/desired.
https://www.sau.com.au/forums/topic/255857-stagea-springs/#findComment-4413430
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
