So, i have dropped in my short motor to start the clean and machining process. At the moment she looks like:
Rb30 block stock as a rock
CP RB26 9.0:1 Forged Pistons
Spool Forged Con Rods
ACL Main and Rod Race Bearings for RB30 (which may change to RB26, as we are deciding whether to water groove the mains)
GTR oil pump
GTR water pump
Tomei Metal gaskets all round including 1.5mm head
new splitfire CP's
RB26 OEM gasket kit for the rest of the replaceable gaskets
GT3540 with 1.06 exhaust housing
Link G4 ECU with 7 Bar MAP sensor
NEW ECU Loom.
R34 GTR Vspec Head
SARD 800cc injectors
Standard GTR TB and Intake plenum.
The motor is replacing an RB25DET making 235Kw ATW in a R33 GTST.
The questions I have are:
What Harmonic balancer do I use RB30 or RB26. I intend to use the RB25 PS pump, alternator etc from the current engine.
Also does anyone know the Gates part number I need to use for the timing belt?
Any recommendations on oil brand and grade for running in?
