  • Replies 71
i got a mates steering wheel on with just putting it over my boss kit, the horn worked, then it didnt and we are like wtf? now when ignition is on i have a AIR BAG light which i have never seen before in my life.. let alone my series 1 even have air bags :s and now the horn doesnt work at all checked all fuses and everything we're just stumped.. we got a wheel on but now no horn wtf!
https://www.sau.com.au/forums/topic/255886-defected/page/3/#findComment-4416426
can series 1.5 have just a drive air bag and no passenger?
edit : mines a 95 and when i got it came with a s2 wing, s2 floor mats, s1 rear garnish, s1 front bar and lights
Most S1.5 only have a drivers air bag, S2 got driver and passenger, judging by the year and all the S2 i think there is a good chance it is a S1.5, maybe even a S2.
Do you have an igniter on the coil pack cover up the back, S2 dont have one.
https://www.sau.com.au/forums/topic/255886-defected/page/3/#findComment-4416454
Hey,
Pretty sure most S1.5 has only drivers airbag, can't remember when I last see S1.5 with dual airbags, You might need S1.5 airbag steering wheel to pass RWC.
Hope it helps.
*edit* Brett, aka W0rp3D beat me into it.
Edited by Count Grantleyish
https://www.sau.com.au/forums/topic/255886-defected/page/3/#findComment-4416461
hrmm thats weird cos when i bought the car it had the 'metal middle bit' steering wheel on it so i just thought it didnt come with a air bag.. maybe if i try my brothers s2 steering wheel.. he just bought a s2 r33 (white as well -_-)
https://www.sau.com.au/forums/topic/255886-defected/page/3/#findComment-4416483
yeah i spose you can borrow my wheel on the weekend Leigh - if you help me with my clutch :D
https://www.sau.com.au/forums/topic/255886-defected/page/3/#findComment-4417500
if you can fit the s1 steering wheel and the Airbag light is your only problem, you need to find the wires which used to plug into the airbag. Then you just need to buy a resistor from dicksmith or something and just solder it on or plug it into the plug. this should trick the system into thinking that the airbag is still there and should work fine.
sorry i can't help with what the resistance is supposed to be, i'm sure someone on here would have done something like this.
https://www.sau.com.au/forums/topic/255886-defected/page/3/#findComment-4417531
yeah i spose you can borrow my wheel on the weekend Leigh - if you help me with my clutch :thumbsup:
hahahaha. +1
yeah globe is your best bet.. or alternatively you could try getting it cleared with that holden steering wheel :)
https://www.sau.com.au/forums/topic/255886-defected/page/3/#findComment-4417712
heres a couple of pictures, see the plug thing on the yellow circle, it just doesnt fit through the slot of the wheel slot, and even if it did the plugs at the other end of the wire dont plug into each other.
https://www.sau.com.au/forums/topic/255886-defected/page/3/#findComment-4417855
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
    • lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
