Definative Answer Needed, Series 2 Rb25 Pfc Model Code
NICKCEFFY
 Share
Hey guy i need a bit of a definative answer please,
i have recently dropped an RB25 into my Laurel, so last weekend using the stock computer and AFM i ran the motor in after its rebuild, then during the week when we went to get it tuned the PFC i have would not let the car start, with the ignition on the computer would switch on get onto the monitor screen but then a relay at the back of the car would keep clicking off an on and the car would turn over but not fire, so then sticking a screw driver onto the 1st and 6th injectors would could not even here them firing.
So the question is what model PFC should i be using, i have one with the seriel number PFC RB259911-0009 but have since found a couple on other cars with the number ECR33010-****
Now going on the premise that if i had any wiring wrong to start the standard computer would not work and if anything was wrong with the PFC it wouldn't even load up as far as any menu's but mine i can get right into the monitor screen and check the AFM values etc, so does anyone know what the deal is.
Also the car has been stripped of excess wiring from the stereo,heaters, any door wiring(windows central locking etc) and air conditioning would any of this be the cause
Cheers
Nick
Edited by NICKCEFFY
the PFC unit you have is correct, there are two versions of the apexi PFC for R33 Skyline
RB25 and ECR33 model codes - both work fine and will no issues, RB25 is first generation, ECR33 unit code is 2nd generation
it sounds like the PFC you have, has a fault with it, or something is wrong with your car
I would remove the PFC, put your stock ecu back in, confirm the car works and runs, starts OK
then if it does, reinstall the PFC and turn the car to ON, but dont start it, the hand controller should boot up and be normal (no clicking etc)
if its clicking, the PFC is damaged or your wiring is mangled (check if car is OK with stock ecu)
cheers guys,
first off, car runs absolutely fine on the standard computer, i've done about 800kms over last weekend running everything in making sure there was no issues with the car before installing the PFC boosting it up.
As for the battery i've relocated it to the boot but as it has been good for starting the car with no issues on the standard computer,
I haven't had another 33 to check the pfc on but i talked to the mechanic who tuned the car it came out of and he said it was fine and had no issues with his tuning,
but also when my mechanic went to try and wipe the original tune of it and start mine from scratch the computer wouldn't allow him to do that either with the laptop or the hand controller.
Could it be that i need to upgrade the main power wire from the battery directly to the computer so it doesn't have any voltage drop travelling halfway around the car from the boot to engine bay then back into the cabin?
Edited by NICKCEFFY
Cheers for your help guys, i now have the problem sorted and the car runs on the PFC,
It was a lack of power issue as you said DirtGarage, it seems in the transplant of putting the 25 into the Laurel i missed out on wiring in the Unswitched power onto the computer and in so getting the full 12v power to the ECCS relay.
Cheers
Nick
 Share
    • Interesting that it has 2 to the USB stick. Are the ones to the USB stick different? Or labelled anything at all? Telstra 4G is Band 28 is the long range one you want, it's 700mHz. I'm trying to do some reading on the Cel-Fi stuff, but I can't find any decent info online that makes me feel comfortable being able to work out the sort of antennas we could get away to swapping it over to. The antennas I'm starting to do some stuff with at work, are a transparent antenna. They're designed to stick onto the window. Which means you wouldn't even have the antenna outside the car. Volkswagen have just started using the exact same types of antennas on some of their new cars (And from the same antenna manufacturer). But, RF stuff is a bit of a dark art some days, and getting it wrong in your car could make for a terrible waste of money trying to swap antennas :S
    • I'm not going to lie Duncan, Saturday and Sunday were pretty rough days. The sort of work I was doing would previously have ended up with me spending about an hour and a half chatting with Neil. Firstly about something I had a question about, and then both of us rambling off on tangents.  I think how Neil did things, and his attitude to getting it done is helping me in part to get this stuff done. Then I can actually do the things I enjoy more easily
    • Talked to another R34 GT-T owner, he said bonnet of his car once fell and slammed from full height because of strong wind at a car show and nothing was damaged or broken, so I guess I'm just overthinking some things but yeah, just making sure I'm not damaging the car anyhow cause wanna keep it for a long time.
    • I would say 100% that it doesn't matter at all. I have an Al bonnet and I drop it sometimes, push it others. Have done so for 25 years and there's no way to tell that either has caused any problems (because there are no problems).
    • yeah, a black 4 door HR, stock AT RB20DE. Was a pretty good daily summer car, it was kept in a garage during winter but previous owner was fighting rust so most of the car was covered with rust undercoating, the trunk, floorpan, it started to rust underneath so I thought it would be better to find other chassis that was taken care better and do rust preventions myself, at least I would know where keep my attention at. Plans are simple, enjoy the car as much as I can, mostly on summer of course, winter here is long and not kind to 90s JDM, I wanna keep it mostly stock like, I'm not a huge fan of GT-R look or any body kits so gonna keep it as metal as possible haha, something more balanced look wise and yeah, work on performance, I was thinking about RB25DET but 20DET actually feels fun, as long as it's reliable I think I might keep it.
