Shitboxes - Help get them off the road.
If you see a smoky vehicle, you can report it to Queensland Transport. Cars burning oil pisses me off as people don't give a shit about upkeep of their cars. So if you see one, report it!
http://www.transport.qld.gov.au/qt/eForms.nsf/F3096E
What happens once you report the smoky vehicle?
The reported registration number is compared with the reported description to make sure they match. If they do, a letter is sent to the owner explaining that the vehicle has been reported and suggesting ways to fix the problem. If the vehicle is reported three times within four months of the first sighting, the owner is issued with a Present Vehicle Order for the vehicle to be checked for defects by a Transport Inspector.
Regards,
Scott
https://www.sau.com.au/forums/topic/25592-shitboxes-help-get-them-off-the-road/
I got one of those letters a few months ago! Pretty funny. As it turned out I already had a motor in being rebuilt, $2500 later, no more smoke from the Gemini. I have to say I was really pissed when I got that letter as I do regularly maintain all my cars and I felt it quite insulting to get the letter when honestly, there wouldn't be a to many BCC busses getting around blowing less smoke into the atmosphere than the Gemini was at that time. I would like a dollar every time I followed a boosted import belching rich fuel smoke into the atmoshpere because they are too cheap to boost their car properly (ie. adjust the A/F mixture properly). Yeah, report a smokey vehicle, but remember I don't know too many people who would be able to swap/rebuilt a motor the instant it starts smoking. If I had got a second letter during the 2 months it took me to organise a motor rebuild, raise the funds and get time off work and had to get a full machinery at my cost because of it, I would have been super pissed. Especially considering it took the QLD Transport department 3 months from the sighting to actually get the letter to me!
  • 9 years later...
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
