thanks alot roman.
i would recommend anyone who has modifications on their car to print this out and keep a spare copy in the car, and get very familar with it.
p.s i would recommend SAU do something like sticky these sort of important documents.
i also wanted to raise a important question about the document.
this was taken from section 8 in regards to wheel sizes.
it states that wheels are determined illegal is they are above 25mm from the wheel spesified on the car OR car series.
what does vicroads clasify as series?
Series of the Actual car (eg R34 GTR or GTT or GT)
or
Skyline series? (R32 R33 R34) would that include the new R35 then?
if so R32s (which came with 15s) could have wheels as big as 20x10 and be legal?
Personally i always thought of it as
Brand = Nissan
Make = Skyline
Series = R32/R33/R34/R35
Model = GTR/GTT/GTST/GT
discuss
Edited by VB-
think about WHY they have these rules and that should help you find an answer. vicroads' rationale is for cars to remain safe and roadworthy by not allowing monster wheels to be put on tiny cars, whose chassis/suspension etc wouldn't be able to handle it properly.
how similar is an r32 to an r35? chalk and cheese, but for the GTR label. i doubt very much you'd get away with it on that basis.
i go by the tyre placard, ie. 25mm wider than the widest rim on there.
your point about a r32 compared to a r35 is taken is but i think your failing to see the point here.
bigger wheels half the time are used to help handle better. its half the reason why you see monster GTRs with something like 18x11 wheels despite then having no where near that big from factory. wether your using drag applications or track, sometimes you jsut gotta go bigger.
i would like bigger wheels on my car and would like knowing its legal........thats all
Edited by VB-
or
Brand = Nissan
Make = Skyline
discuss
Always thought it was,
Make: Nissan
Model: Skyline
Series: R32/33/34
In the VicRoads documents, I've always translated the 'widest for that vehicle series' as in the widest that series has got. For example the R32 GTSt's only got 15x6.5" wheels where as the GTR's got the 15x8". The 15x8 was the widest from that series (R32) so you could legally go up to 9" wide (both on the GTSt and GTR) and whatever diameter as long as it's 15mm within factory rolling diameter (total, both tyre and wheel).
No idea if that's correct or made sense, but I always thought it was like that. :laugh:
Edited by adam-__-
thanks alot roman.
Umm there is one... :laugh:
Its called the EPA/RWC thread in this very section thats been there since Feb 2007.
As for the actual VicRoads VSI documents, there is no point uploading them.
You should always download from the website if wanting to view them incase there are ammendments and so on.
So uploading the to the forum itself would not be beneficial on the chance it proves old/outdated information
Don't quote me as I'm not certain, but back in my FordForums days, I remember everyone saying that they could run XX size and diameter wheels on their base model Falcons etc due to the XR's in that series having XX size wheels.
I think it goes off the largest available factory option for that series. So for example a BF Typhoon came with 18's, but optional 19's therefore you could get away with 21's if the rest of the dimensions were within the guidelines...
As far as translating that to Skylines, it's only really the 34 that has anything 2" bigger from GT-R to GT-T, with 33 GTR's only being 1" bigger than GTS-T's, but that'd still allow 33's to run 19's as long as the widths and tyre sizes were within the guidelines...
Think there's also another rule of any wheel/tire upgrade having to be within 15mm of the largest/smallest factory option wheel/tire package for that car...(included smallest as you can't run 13's on a car that should have 17's etc)
theoretically you were to go on the bases that 15mm was the largest/smallest size package, you could essentially have 25" wheels so long as the tyre is small enough to compensate for the 15mm no?
I think there's more than the 1 rule as far as wheels go...So you might be within the 15mm rule but outside the other ruling as far as wheel size goes...From memory its 2" up/down on the largest/smallest factory option
wat i would like to know is what vicroads clasify as series.
if indeed they look apon series like like dezz said. base model falcons being compared to high end XR6s, it should apply with skylines aswell.
the new R35 sports 20 x 9.5" (front) and 20 x 10.5" (rear) .
which would hopefully mean i can run my 19x11s on my car :laugh:
i think what dezz meant was that you could run the width out of your serries, so if you have an R33, you have to keep to the max width that was available, so that would mean R33 GTR size wheels, plus that 15mm rule
It's all in plain English..
Falcon, say a Ba...regardless of spec it's still a BA series falcon. So if the largest diameter rim is 19 x 35 x 235 from the factory you may go 15mm oversize in rolling diameter and up to 25mm in width.
Skyline, r3- series whatever....blah blah, same deal, regardless gtr,gtst,gts ect you can go 15mm taller in rolling diameter and 25mm wider over factory spec
Yep, thats what I meant. Not that you can go off what the R35 has....
So basically all GTS-T owners would go off GTR specs as they're going to allow you to run the largest wheels
As for fords, EF-EL would go off EF-EL XR's, AU off AU (series 1, 2 and 3) XR's and so on
yes wider wheels can give you more traction, but what ric is trying to say is that cars are designed with those wheels in mind... so certain suspension components are also engineered to work in with the standard wheels.. and a large change from standard specifications can have adverse affects, such as the wheel bearings.. if you go too wide with a very drastic offset, you'll start to load the wheel bearing beyong thier engineered tolerances! so the limitations imposed by vicroads and adr, are not there to stop you having fun with which wheels you want to put on your car, but as a safety guideline.
^^ or even snap wheel studs and so on if the car is too low and rims dont sit right etc.
There is a can of worms so to speak about all the possible dangers... ye you might not be bad yourself, but this is the majority of society and some of the stuff you see on the roads is a clear reason why these laws are there as they are just dangerous
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
    • I'm pretty sure if it's considered a gasoline powered vehicle you have to do certification against a fixed, very expensive certification fuel.  If you add two precats and then replace the main cat with two cats back to back you can get an RB26 to do 0.24 g/mi HC, 1.6 g/mi CO, and 0.3 g/mi NOx on the FTP-75 drive cycle. Found this out courtesy of California's laws at great expense. Divide by 1.61 to get g/km. So even with extra cats + precats you're blowing past the NOx limit by probably 2.3x. Probably the only way to get an RB25 or RB26 to meet euro 4 purely from an emissions per km standpoint and not durability/OBD2 requirements is retrofit at least intake side VVT, clearance the pistons to allow the full 50 degrees of advance so part throttle EGR can be maximized, and change the wastegate control from conventional 7 psi spring for example to one that is always fully open if the wastegate line is at 1 atm or higher and only close it in response to vacuum. See BMW's N54 engine as a reference for how this works. You would need to find space for a vacuum tank to function as an accumulator in this system. That way you can avoid any heat loss to the turbine as much as possible during cold start to heat the catalyst faster. Then find some way to eliminate as much as possible cold start enrichment to light off the catalyst rapidly. Maybe secondary air injection if there's no way to avoid cold start enrichment. Close coupled catalysts in the downpipe are probably necessary. I would also probably swap to EV14s, pick something with the correct spray targeting + dual cone pattern for the intake manifold you're using. EV1 style injectors to pass anything resembling modern emissions requires a very annoying air assisted injector system to break up the droplets at part throttle/idle which still doesn't work that great compared to just having smaller droplets from the injector to begin with. Realistically, you're probably going to be financially ahead if you just pay the fines instead. Or don't drive it into the city center. There's a reason why Nissan never bothered to even attempt certifying an RB for CA/US emissions. The VG30 needed external EGR on top of NVCS to pass in the 90s. Doing all of this work is also distinctly expensive and you're going to struggle to find anyone who is remotely interested in helping.
    • I remember those, people use to steal them to make bongs.....
