Help :( R32 Hard Brake Pedal, Can't Find Out What It Causing It.
Heres the story:
Bought an unreg R32 GTS4 that had been sitting for a while. And now it wants to go over the pits and has failed twice for a hard brake pedal. So far this has been done:
Brakes bled
Front & Rear calipers reconditioned
New pads fitted
Master cylinder reconditioned
Rotors skimmed
Brake booster pressure tested
The brakes react to first part of pedal travel but go solid when trying to press hard, ie in a emergency stop. This is why pits said they won't pass it.
NOTE: Car has factory ABS fitted.
So far, can't get rid of the hard pedal. Beginning to suspect while booster has passed pressure test, it is miss-performing. Has anybody got one that they can lend me to test? Or if it comes to it, anyone have a good condition one to sell?
Anybody had this problem before? (Rmb ABS fitted)
0431 985 155 is my dad's phone number (Tony).
(I'm still on Ls)
Sounds like air in the system,
But if you have bled them, it should of corrected the problem.
There is a particular way you bleed the brakes with ABS as well.
Not sure if that is just for GTR though.
Other than that, I am stumped!
Yeah, it's been done by my mechanic who used to do ferraris lambos tractors :thumbsup: (ex-barbagello) etc etc, basically fixes anything, except my line!
It doesn't feel like air cause if just driving normally, they are fine. Its when you brake to a certain point that it becomes rock solid and you really have to press hard for the car to stop. (Don't get me wrong, it stops really well, its just the hard pedal) The guy at the pits said sure, your average joe could stop the car, but he's referring to when say eg a girl is driving and they can't press the pedal, ie making it too dangerous.
I want the car on the road :| This is the only thing stopping it and its starting to annoy the hell out of me. Stupid skylines :P
Edited by Ten Four
Doesn sound like air in the system, that gives the opposite effect. You put your foot an the brake and nothing happens for a while because you're compressing the air.
Sadly, I cant think of what it might be.
Rhys,
Air in the system can in fact cause block peddle mate,
I understanded where you are coming from,
But to discount air from the system completely at this stage, may in fact lead you down the incorrect path.
There is a sequence that you have to bleed the brakes with ABS in a skyline if it is to be done properly.
There is write up for this in the GTR Manual that can be found online.
Once you have cleared the system completely, then can you move onto the next fault finding excercise.
Nav had a very similiar issue with his car.
Cheers
Mike
Thanks for the replies guys.
Flash, it's not much different, both on and off are pretty hard.
Mike, where is this guide? Otherwise the air has been pretty much discounted at this stage. Its acting more like the booster so I'm going to try get one (to a point its fine, after that its just hard). Cause the car still stops really well, its just the firm pedal.
Defective, the lines are not twisted or split cause each was tested. Brake fluid was replaced earlier today.
Ahh 33, I think I may just do that, thanks.
Edited by Ten Four
Have you tried taking it and stopping by a couple of performance workshops to get their opinion on what it could be? They might have come across this issue before and know the solution.
Yeah mate, as a last resort I will probably end up taking it to a performance workshop. I'm sure the problem is something silly. If the brake boosters I've just bought and the disabling the ABS don't fix it, I'll take it to one.
Who idea was it to do the above mentioned repairs ??
Get a Brake specialist to check it out . ( a good one also )
Rhys,
Cheers
Mike
Mmm i know you might be the guy who gave me the warn on this but ima have to say fail on that one aye, as a mechanic i can say that air in system will cause a spongey pedal and lesser response upon application
Its sounding more like booster but also check where the vacuum line connects to the manifold, start it with that line off and make sure its sucking in air, also check that the booster vacuum hose isnt sucking closed under vacuum when you push the pedal
Dsturbed, the car had been sitting for 1.5 years so the above jobs were done as to be expected. However, it didn't change the brakes much.
Takushi, that has been done a few days ago.
Update: it isn't the ABS.....
Edited by Ten Four
Hey might sound odd but can you post up a pic of the brake booster....
i had a brake specialist test my old TX-5 booster and it was fine then i had the same problem..
i found there was a one way valve in the booster due to boost and it was the wrong way around :D so please check you dont have one or it is the right way around.... also you say you tested the line,,, did you actually start the car with a vacume tester on it then rev to boost to see the difference?? and what was the difference??
Hi guys, problem seems to have been solved.
Previously, the master cylinder must have been taken apart as a washer was missing and the piston was bigger than usual (looked like nothing was out of place...). Replaced washer and put a shorter piston and it seems to have solved the problem. In essence, the car still brakes just as well as before, just with a softer pedal now.
Will be visiting the pits tomorrow.. Cheers.
Edited by Ten Four
Guest
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
