Find that hard to believe as my 10' +18 were poking out of the guards.
The outer of a 9.5 +12 and 10 +18 will sit in the same place... just 12mm more clearance on the inside.
Interesting pending weigh in pete :banana:
btw sell me those panasports :D
  • Replies 40
  • 4 weeks later...
  • 4 weeks later...
um new rims in stock now
price has slightly changed after i just had another order ausi dollar ect
sizes
17x9.0 +25 $339 rrp fatz price $293.15
17x9.5 +12 $349 rrp fatz price $301.65
18x9.5 +12 $389 rrp fatz price $335.65
shipping prices
Price per wheel, no tyres:
NSW, QLD, VIC $15
TAS, SA $20
WA, NT $30
all in stock and ready to roll
righto i finally weighed them and got picks
Rota P45-R
17x9in +25 9.77kg
17x9.5in +12 10.12kg
18x9.5in +12 10.74kg
17X9.5
18X9
18X9.5
they can also get these
17X9
17X9 +30
Edited by fatz
those last ones in 17X9 +30 with a set of nice 235/45/17s on them would go very nicely on a 32 GTST. I had that same size and offset on my old black 32 GTST and they sat perfectly flush with the guards and did not rub or touch on anything and looked great. I might grab a set for my silvia.
looked like this with 17X9 +30 on a GTST with stock suspension and arms etc. perfect size and offset for them.
Guest
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
