Originally posted by Winberg
I use 3dsmax/rhino for modelling..Vray for rendering..
Photoshop for adjusting..
-Tom
How hard would it be to do *this years* JGTC GT-R?
Top work by the way!:D
  • 4 weeks later...
amazing work winberg
how long did that take u?
u've put a lot of detail into it
u even did the gtr logo so flawlessly
and umm ye redlinegtr i was the one who did the r33
also done a 350z
here's an animation of it lol
http://rk.qgl.org/350z-dorifto.avi
