Fs: 93 Gold Jap Spec S6 Fd Rx-7 220kw Dalton Automotive Built Carbon Bonnet $16,000 Ono
For sale: is my 1993 series 6 fd rx7 which i have owned for 3 years which has been fully rebuilt from ground up with $10,000 worth of reciepts. Car is currently 220kw's at the wheels with a Fully rebuilt race engine by dalton Automotive costing $8000. Car has a full Cwest bodykit and Mazdaspeed vented carbon fiber bonnet. The car is uncomplied and can't be registered on the road as it was brought in as a Race/Rally only import as it was bult with the intentions to use it as a drift car. Lots of time and money in this car and it hardly gets driven and sits in the shed so it needs to go to a new home.
Here is some of whats been done to the car...
Engine:
Fully rebuilt engine with new rotor housings
competition apex seals
new side and corner and oil seals
Fully turbo ported with extra dowells X8
rebuilt turbo's(with sequential removed running 1 bar boost)
ported and machined exhaust manifold
hi volume intank fuel pump
Custom dalton automotive heavy duty cluch kit
malpassi fuel reg
Microtech Lt10s computer with hand controller
bigger injecters
x4 new bosh coils
Hybrid front mount intercooler with stainless steel piping
turbo xs boost controller
3" turbo back mandrel bent exhaust
stainless steel muffler
Exterior:
Full C-West body kit(series 8 front)
Full metallic gold respray (paint in ok condition)
Series 8 lights
18" Jap rims with new tyres
Interior:
Apexi EL2 Boost controller
Apexi turbo timer
Drift steering wheel
Microtech handset
Item Condition:
Car is in excellent mechanical condition with all work done by Dalton Automotive. Car has just been re-sprayed a custom gold colour 3 months. Some area's of the bodykit have some small marks in the paint which are only noticeible close up. Everything on the car is prety much brand new with a new walbro fuel pump just fitted 2 months ago cost $450.
Price and price conditions:
Asking $16,000 ono or may also consider swap for other turbo car. Please e-mail pics and a small description of the car.
Extra Info:
also comes with massive hks turbo and trust external wastegate with a D1 style screemer pipe(which vents below drivers door) Not fitted. all it needs is an exhaust exhaust manifold to suit then the car will make 280+kw. I was intending to get it fitted but just dont have the time or cash to finish it.
Pictures:
Contact Details:
Please no time wasters! genuine offers only!
[email protected]
Geelong Vic
Delivery & Conditions of Delivery:
Pick Up Only
Real nice rx7. If it was able to be road registered i would have snapped it up asap
If it was able to be road registered it wouldn't be at that price :D
    • I just bought the Nexus S3 for my gtt, haven’t installed it yet as I’m collecting parts to do everything at once…so far spent $14,000 The Nexus is nearly future proof
    • Honda's hybrid system can be easily scaled up to PHEVs. Series hybrid at low speeds, at higher speeds the engine directly drives the wheels but there can still be some power bled off to charge the battery + the electric motor can still provide parallel assistance too. It's really only a question of will at that point. Toyota's PHEVs are selling incredibly well at the moment because of the flexibility. You can run on EV mode when it makes sense, but if you're planning on doing a long highway drive you can still fire up the gas engine and not have to worry about dealing with the rather miserable state of public charging infrastructure.
    • Only reason to keep a MAF on your RB25 is to be able to easily calculate true VE if you know what the factory voltage curve represents in grams per second of flow. Also allows you to do things like pull the original OEM ignition + AFR target tables and use those as a starting point for your base map. Once you're well and truly done tuning though there's no need to retain the MAF.
    • Do you think they'll merge there performance divisions and we'll end up HoMo?
    • Very true, if buying new, I would not get an PP either. Minimum is an Elite 2500, which is also considered outdated. Get something that supports DBW, delete that cable throttle. Best thing I've ever done to the Skyline, next best is refreshing the A/C with a new condenser. It's cold, but not as cold as modern car, but colder than most 90s JDM shit boxes imported into Australia.
