Hi
Just thought it would be worth saying that we have now started a UK Stagea owenrs club. :D
The numbers of Stageas in the UK have been steadily increasing and we are up to about 50 - thats people who have actually put their name on our forum as owning a stagea . Obviously there are quite a few more.
As of today we have 25 paid up members . This is not bad as we only started the club a week ago . I am sure we will get the numbers up quite quickly.
We have a stagea secton on the GTRoc website for about a year. http://www.gtr.co.uk/forum/general-stagea-chat.html
If anyone wants to join in the chat feel free though you may have to register to post
The guys are very enthusiastic but not as knowledgable as you guys as most have only had the car for a few months.
Most have RS Fours but there are a few RS 260s and some with RB26 manual conversions some of which are running quite good power.
Thanks
https://www.sau.com.au/forums/topic/256001-uk-stagea-owners-club-now-started/
Hi
Thanks
Well done. I was under the impression there were only 2 or 3 Stageas over there. Now you'll have to have a rally and impress the locals with your unique cars!
Tunnel Runs? Are they still popular (legal) in UK? legal NO popular YES
Convoys (more than 5 cars) are not legal in the uk but meetings are ok . We really do have some crazy laws.
I suppose we drive there in groups of 4 on the same road
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
    • How old is the battery, it's more likely your battery is on its way out.
    • I reckon you'd get 90% off. My washer doesn't get between spokes very well. Haha! I love my Gerni!  Argh! Steam cleaning has its place for sure.
    • Hey all, I did a voltage test with the car (video attached) not running for 3 days. And here is some interesting stuff: - Battery voltage is 12v (I had the key in the ON position) - Drops to 9.76v while cranking then quickly goes up to 14.5v - You will notice there was a sorta slow start but not as slow as it usually is. - Idle surprisingly was better at just over 1,000rpm instead of 1,100 rpm. - I turned on the A/C, radio and headlights in the video and the voltage remains the same - I haven't cleaned the grounding wires on the chassis yet, that's next. - Battery drops to 12.6v when I turn off the car and wait a bit Seems like I might have a parasitic draw? I do have an immobiliser system which does drain the battery more of course but was wondering if there is anything else I should be looking at fixing? Does the ground wires on the chassis have anything to do with the low 12v?        SAU.avi
    • My lord that is some low oil pressure as minimum in the manual! I guess the big part will be seeing how it changes as the engine gets more spirited use.
