R32 Gtr Hell Yer
THIS CAR HAS EVERYTHING AND TOP END BRAND NAME PARTS WELL OVER $70K ON THIS THING
JUST HAD NEW PAINT JOB DONE NOT ONE THING NEED TO BE DONE DRIVE IN AND ENJOY THE BEST OF THE BEST
ONLY GETTING RID OF IT BUSINESS IS NOT GOING THE BEST SO NEED TO PAY FEW BILLS I WENT OVER BOARD ON THE CAR :D
CAR HAS BEEN IN FAST 4S MAG AND ABOUT TO GO INTO ANOTHER
NOW PLEASE I PUT THE PRICE ON IT WHAT I THINK IS FAIR PLEASE NO WANKERS PLEASE THE PRICE IS A LITTLE NEG
I WILL SWAP FOR A CHEAPER CAR BUT NO TURBO PLEASE JUST A LUXURY RUN AROUND THANK YOU
PRICE IS $52000 ONO
HAS FULL BLITS GAUGES INSIDE ALSO NEW HKS EVC BOOST CONTROLLER
HAS R33 GTR SEATS ALOPT BETTER SO MUCH MORE STYLE MAKES CAR LOOK ALOT NEWER INSIDE
FULL CUSTOM BLUE PAINT JOB
17" RACING SSR RIMS 90% TREAD
CP PISTONS AND RINGS 86.5MM
EAGLE RODS
TOMIE FULL METAL GASGET SET
TOMIE OIL PUMP
ATI BALANCER
ACL RACE SERIES MAIN AND BIG END BEARINGS
HKS VALVE SPRINGS
ARP HEAD STUD KIT
ARP MAIN STUD KIT
NISSAN GASGET SET
JUN CRANK COLLAR
TRUST SUMP EXTENSION
HKS FUEL RAIL
SARD FUEL REG
HKS 115MM THINK INTERCOOLER
HKS CAM GEARS
POWER FC ECU
GARRET GT35R TURBO
TOMEI PONS CAMS \
TWIN PLATE 800HP CLUTCH
TWIN Z32 AIR FLOW METERS AND PLUSG
sard 700cc injectors
MAKES 550HP ON 23PSI VERY SAFE TUNE
19PSI MAKES 490HP
VERY FAST CAR
Edited by bigme
ONLY GETTING RID OF IT BUSINESS IS NOT GOING THE BEST SO NEED TO PAY FEW BILLS I WENT OVER BOARD ON THE CAR :geek:
PRICE IS $49000 ONO
EAGLE RODS
TOMIE OIL PUMP
ATI BALANCER
HKS VALVE SPRINGS
ARP HEAD STUD KIT
ARP MAIN STUD KIT
NISSAN GASGET SET
JUN CRANK COLLAR
HKS FUEL RAIL
SARD FUEL REG
HKS CAM GEARS
POWER FC ECU
GARRET GT35R TURBO
TOMEI PONS CAMS \
19PSI MAKES 490HP
VERY FAST CAR
 Share
    • Un able to check it at idle as it won’t idle for me long enough to try, best I’m able to do is with ignition on engine off and no matter where I turn the tps the voltage doesn’t change from 5.10, if I unplug afm it will idle longer but won’t turn off with ignition, have since swapped afm to no real change
    • Gone into r34 gt4 non turbo model
    • Sorry to sound thick....but what does the "faceplate" have to do with adjusting the odometer? Surely the odo stays put and you change the fascia. Surely they are not the same thing.
    • I know its been 13 years since this topic, but it came up when i was searching to fix my problem so thought i would add my 2cents in and how i fixed my issue.  my r33 had air coming out off all the vents except the center one. i went straight down the rabbit hole expecting it to be a mechanical issue, pulled the dash apart tracing lines, checking linkages etc. it turned out the very fine fly screen mesh behind the center vent was actually VERY blocked so when i had the air on face the air would take the path of least resistance and come out the 2 side vents but allow nothing out the center vent. a quick clean fixed the issue. once the mesh is clean you can see the air direction flaps moving inside through the mesh.
    • Glad that worked out for you. I think my Joyeauto one is coming this week but I won't get to install it til closer to end of October. Will update when I get around to it. Just standard CP and nothing else. Hopefully the cameras all work without needing to get out of CP and get back in as they advertised. My other worry is sound quality. Fingers crossed!
