Hi SAU , ive recently bought a set of new rims and they are very dirty and self car-wash functionality just wont clean it.
Im thinking to get one of those cheap Engine Degreaser $4 (one of the 5stars shitty brand, coz good one probably be too harsh for the wheels).
However im worring about it will take the clear coat off as well as the centre cap as its plastic painted on. (stupid mate has his center cap paint ripped cuz he used engine degreaser :D )
Apparently you could wax them after cleaning them so the dust wont stay/stick onto the rims.Would just like to confirm if engine degreaser is safe for Froged Rims.
i would assume a wheel brush is essential for this job ?
p,s, what cleaning products you guys use?
Cheers
https://www.sau.com.au/forums/topic/256012-what-to-use-for-cleaning-rims/
What to use?....The girl friend :thumbsup:
I just use the standard car shampoo and try to get the brake dust off asap. Zymol make a coating that goes over the cleaned wheel to make it easier next time. Never tried it. As it's Zymol it will not be cheap
AUTO GLYM Wheel Cleaner or Maguires Mag Wheel cleaner.
Its pretty acidic stuff if you take a sniff at it. Spray it on the wheel and let it soak for about 15 sec / 1min depending on the instructions.
But I spay it on, scrub as quickly as you can with the wheel brush then hose of ASAP.
Or just wash your wheels with car wash and get the elbow grease into it... SCRUB HARDER!!!
LOL!
Yes but then all your volk stickers come off...those pesky things!
wonder if someone can powder coat the label on at the same time as they powder coat your rims...
LOL!
How did you know I had Volk stickers? Or you probley have Volk rims yourself.
I must say the stickers are stuck down on the wheels are quite hard to get off.
Previous owner tried to peel off the RAYS ENGINERING sticker but did a half ass job on my wheels.
For the love of god don't use degreaser, use a clear coat friendly mag/wheel cleaner if you must. Something from Mothers, Meguiars, Autoglym, not some cheap ass crap you buy for $3.49.
Once they are nice and clean, you can use a wax or polish on them to protect them from UV and stop the brake dust from imbedding into them as quickly. Then just wash them normally when you wash the car to get rid of the brake dust, however make sure you use a pH neutral shampoo that doesn't take off wax (eg. Meguiars soft wash, Mothers gold class etc). Make sure you clean your wheels last if using a sponge, cloth etc, so you don't scratch your paintwork from the build up of dirt on the wheels.
With this method, you won't need to use wheel cleaners.
Edited by PM-R33
  • 2 months later...
meguiars non-acid wheel cleaner is tha shit. very good for cleaning you nice forged jap alloys. you'll need to get a bit of elbow grease into it too though if the brake dust is really baked on there.
has anybody ever used oven cleaner like Mr sheen? just wondered about this coz i use eagle one wheel cleaner stuff now and i was thinking it seems to spray on like over cleaner? anybody game to give some a try?
dont use oven cleaner - they are cuastic and will east paint fast.
great for cleaning baked on oil under rocker covers though
^^that. i've tried all the ones available at your autobarn or repco, and the mothers ones are the best. just be careful when you spray onto your wheels after a drive. if it hits your rotors and becomes steam, you'll choke on the shit
clean your rims properly once. Then each week...
1) wet rims (HP rinse preferable)
2) spray PWC
3) let it dwell for a bit
4) HP rinse
that's it. PWC will get rid of weekly build up without breaking a sweat.
Even if you don't have time to wash the entire car, just do the rims. Clean rims and glass can do wonders if you're in a rush.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
