Wtb: R32 Gtr Rear Wing + Momo Steering With Boss Kit 4 R32
as title stated, im lookin a r32 gtr wing to fit on my new gtst, color must be in blk, also im keen on upgrading to momo.
im in adelaide and let me know if anyone help this,cheers
0433 260866
bob
  • 3 weeks later...
