Hi all
I have one of those stupid XANAVI units in my R34 GTT and given that it has the RCA connections in the boot, hence I though I could avoid spending money on a new head unit for a while.
That said after i have connected the red and white audio cables in the boot, how to I switch to that input?
Thanks in advance
btw has anyone translated the xanavi dash controls?
https://www.sau.com.au/forums/topic/256017-r34-gtt-xanavi-aux/
Hi all
Thanks in advance
________________________________________________________________________________
its unclear what you expect to achieve ( e.g. are you trying to install a CD MP3 hu in the boot to feed audio directly into the sender box in the boot and onto the Xanavi hu in the dash and if so why? - you do know that the Xanavi hu audio (as produced by the cd player for instance) is actually sent on via the std cassette radio unit thru to the speakers and not directly to them? have a look at the back of the Xanavi hu and all will be revealed by the mass of connectors!!!!!!!!!)
so, you need to be clearer as to what is your real objective (and hence we will know what is your real question?)
and as for the translation of the function buttons on the Xanavi hu this is on a post on this SAU site - use the search facility - the exercise will be rewarding as it may turn up extra info
pm me if stuck after fully trying the search function
To make things clearer, as you said i'll explain what i am trying to do.
I had plugged a digital tv tuner in to the rca inputs in the boot (video, audio left and audio right). I was doing this so I could tune in to the local tv brodcast and watch it thought the factory pop up screen. I then supplied power to the tuner and set it to output the signal as NTSC.
My question was...
After I had done this I was wondering how I could then set the xanavi to display the output of this dtv tuner?
But since then I have figured out how to and not only that I also found out how to play an mp3 player through the xanavi using the inputs in the Dash
My question was...
___________________
SELF-HELP IS WONDERFUL AIN'T IT
My question was...
can you share your finds here ? a lot of people ask this question on how to reuse the standard screens ? and also the any wiring found in the sat nav plugs ?
cheers
usually with a dead navi the only way to do it iw via RGB->composite boxes. few will spend the money to do it.
I THINK YOU HAVE LEFT EVERYONE WITH THE QUESTIONS OF WHAT IS INVOLVED - BRIEF OUTLINE WOULD BE HELPFUL - AND COST?
be nice and I'll explain (IE do not yell.)
box is $500 or so and it will adapt/split a video signal into its raw colors and sync signals. as for doing it - not explaining that one. its NOT a DIY thing.
___________________------____________________
fully understand the commercial in confidence and protection of intellectual property thingy - so (does this really have to be as hard as pulling teeth out ?) the next question is can you supply a d.i.y kit so a R34 owner wherever they are in Aust or the world can pull out the Xanavi hu and discard it and install/just plug in your kit (maybe together with some specific new h.u. or incar pc recommended or sold by you) into the existing car wiring loom (and using the in situ connectors for the screen) - you do not have to reveal the techie details - and get some functionality back (i.e. at least the capacity to play dvd/audio, and maybe tv and or sat nav a higher cost option)?
yes/no? - or what can you do?
est total cost/time to deliver ?
no. there are specific connectors in there that I cannot source.
if you are inclined to do so - try. the people that make them (yazaki or AMP.) will sell them to you in 10k lots.
if you are the person from gatton - yes I can do your car - yes it will cost 2-3K to do properly and no it cannot be put to english.
_____-_______________-________________
Who's the anonymous interloper from Gatton and what has he/she to do with this thread? (Rhetoric question - actually needs no reply)
These multi convo posts never work out.....................................
You could always wack on of those portable dvd players(with RCA and NTSC Output) in the boot, If you just want to watch DVD's? But it would be inconvenient to control the DVD Player since it would be in the boot.
You could get a in car pc with a M2-ATX-HV 140W 6-32V Wide Input Intelligent Automotive DC-DC Power Supply or similar (so the computer starts and shuts down with the car).
Then some how convert VGA to RCA Video (NTSC) this maybe?
http://cgi.ebay.com.au/VGA-to-TV-Converter...tem370157902984
Then get a wireless keyboard/mouse a run the receiver to the cabin.
If you want GPS get a USB receiver and put it on the parcel shelf.
If you want TV get one of those USB DTV tuners, u'd need a decent aerial
And obviously if you want to play DVD's u'd need a DVD RW+- drive in the PC
That's my lame notion, not being full on techie, was gonna look into it but never got round to it
that would work :D
though if you were going to that extent I would drop the video converter and do it with raw video. the IDEAL thing with that would be to reuse the one in the OE DVD unit :)
in all thats quite a good solution for it.
this is another:
http://www.hitv.com.au/products/view.jsp?id=1&category=7
that is basically a windows box running CE. hack that and chuck on what ever apps you like. it WILL do touch screen as well. standard it does GPS,movies and speed info.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
