Was told that TPS was dodgy was causing the idling, gearshift problems & tight steering when backing out driveway. So I had to buy tps through Nissan and after a week it turned up. Fitted last thursday, took car for a drive and was no better. Yesterday I checked tps volts via Apexi AVCR, new verses old and there was no real difference??!! New read 1.13v closed & 3.98v open. Old read closed 1.3v & 3.95v open. Does anybody have any tips so car doesn't have to go mechanic on tuesday?
https://www.sau.com.au/forums/topic/256022-dodgy-tps/
That fault code could have been there for years, it stays in the memory, even it if it detects a glitch for a split second, ie, tps may have been dissconnected during some maintenance in the past thus logging a code. Best way to check is clear codes first and look for codes that appear repeatedly. You may have several problems, cant see how idle problem can be linked to tight steering.
https://www.sau.com.au/forums/topic/256022-dodgy-tps/#findComment-4414285
If the car is idling weirdly and lower than normal the steering will get tighter as the power steering pump isn't being driven fast enough.
I have an after market ecu and for a long time the car would almost die as i came to a stop, or would actually stall at the lights, more so at night with the headlights on. Blamed my tune for ages and kept getting the tuner to retune the issue, wasn't getting charged for it. After a while he noticed that the tps voltage would intermittently "bounce around", at idle. Replaced the TPS and all fixed, idle is alot more stable too.
Have a look at your tps voltage, while the fault is occuring. See if it is changing by itself, without any throttle input. The sensor could be fine, but the throttle shaft, etc, could be loose/worn, causing false readings.
Could also be an ecu issue.
https://www.sau.com.au/forums/topic/256022-dodgy-tps/#findComment-4414303
Yer have read those volts needed. Just double checked at computer and had same closed volts as SAFC (1.3v). Just took for a drive. 4wd and check engine light stay on. A/T light flashed 4-5 times on startup. Getting worse!!!
Edited by skidkid
https://www.sau.com.au/forums/topic/256022-dodgy-tps/#findComment-4414414
Need to clear all codes first as Chook said...make sure u get the "55" code which is no malfuncton after reset.
TPS fault code is "43" see if you get this once you have reset your ECU.
If still have the code, from the R34 service manual this is how you set the TPS;
1. Rotate sensor body until you get the specified value on your multimeter (specified value is 4.6V). From memory connect one of the middle pin TPS wires and good engine ground.
Do this with;
a) IGN switch "ON"
b) engine NOT running
c) Accelerator pedal not pressed
The TPS code will trigger when the output voltage is 4.7V or greater (open circuit) or less than 0.3V (short circuit) for predetermined time while park/neutral switch is OFF and speed is 4km/hr or higher.
Give it a go and see how you go. Make sure there are no codes left in system once sorted i.e reset ECU again.
Edited by RS4StagMan
https://www.sau.com.au/forums/topic/256022-dodgy-tps/#findComment-4414826
    • I have an Elite 2500, honestly most of this has been a lot of smaller tasks chasing little details and a whole lot of life getting in the way of bigger projects. I don't mind too much looking at a spectrograph vs having audio knock ears.
    • Nah nah nah nah. Don't do it. It's not all about the full throttle power delivery. The main "street fun" and drivability gains from smaller rear (in this case) is how you will have boost available from a low rpm when yo just roll onto the throttle. Think jinking in and out of traffic, coming out of roundabouts, etc etc, where you just want to roll onto the throttle a little and have the spooly noise from ~2000rpm and a swell of torque. More of what you've already achieved by going to 2.5. And then, towards the tail end of 2025 you can pull the turbo 4 out and put in a V8 like we originally suggested. :P
    • Cheers for the info mate, I'm old too, 60 years old next May, so a more linear delivery of the 0.86 would be better as baking tyres and snapping heads isn't on the cards for me or the car I assume a more linear power delivery would be better for engine and drivetrain reliability as well, IRT the torque load at lower RPM???, as well as lower EGT's???, if my understanding of that is correct, have I got that right??? I've only got a really basic understanding of turbo sizing and all there characteristics  Cheers for the useful information
    • What kind of power delivery are you after? If it's nice and linear, the 0.86 would be better. If you're after bake tyres and head snaps on boost the 0.64 would be fun. I'm boring and old, so linear power is preferred. Lately I've been watching videos on Z06 Corvettes and super charged Mustangs....
