Well....
As a few of you are aware on the past 26 months I have been building a stroked rb20 making it 2438cc. On the 10th of january this year it was all set to be put on the dyno and the run in tune done, 45 minutes into the tune 5psi dialed in second full pull to the limit of 6500rpm whole heap of oil smoke poured out of the breathers and a bad tick developed on the down rev.
We stopped the tune straight away and pulled the car off the dyno and took it back home and pulled the engine down to find 2 bearings and literaly destroyed themselfs...The Cause.... Still unknown..
Here I am now... Stuck with the choice... Should I spend $2000 to fix it and try again or should I part it off and cut my losses and just buy a 25 or 26 and be done with it and settle down?
Of course my minds leaning towards selling it all because it has been such a effort tracking down all the parts from Japan and the USA nad I dont know if I could do it again to repair it, I have spent the last 2 + years revolving around this build everything has been about it, and I always told myself if something went wrong that would be it I would stop there!
Tough times ahead with money etc. and having to purchase a house in the next 12 months are just clouding my head and I'm not sure what I should do, So I thought I would come on SAU where I have spent much of my time reading and askign questions to see what you would do if you were in the same boat?
If I did part out the engine I would be selling things like the following:
6Boost rb20/25 T4 Split Manifold
RB20 Forward Facing Intake
Ported rb20 Head
Tomei 272 9.25mm IN & EX
Tomei Lifters
Tomei Shims
Tomei Valve Springs
TOMEI Head gasket 83mm 1.5mm
Spitfire Rb20 Coilpacks
Garrett T04Z .86 Rear 3500k's
BMI 80mm Throttle Body
Synapse 50mm Wastegate
Turbosmart 50mm BOV
HKS Tripple Plate Clutch
Sard RB26 Fuel Fail & Braided lines
Sard 650cc Injectors
Sard FPR
Nissan RB26 Oil pump
N1 Water pump
83mm ROSS pistons & rings
Eagle rb26 Rods 21mm bush
HKS Oil cooler
52mm Alloy Radiator & thermos
HKS Cam Gears
New Gates Timing Belt
Ross Balancer
Rb24 Block
Then just drop in a RB26DETT and be done with it and be able to drive the car again.
But If I chose not to part it off and replace the damaged items and hope it didnt do it again would be able to be hopefully a reliable 350kw unique setup.
So what would you do?
Cameron.
https://www.sau.com.au/forums/topic/256060-what-to-do/
If it were me and i had spent all that coin whats another 2k into the equation, i would chuck some new bearings in and double check all your clearances. I remember when i was building my clevo the block prep alone cost 2K (line hone, balance, bearing clearances etc) Build it then pull it down just to double check everything before winding 25psi into it.
https://www.sau.com.au/forums/topic/256060-what-to-do/#findComment-4415002
hmm I have been thinking alot of this in the last few weeks... I do want to finish it it just plays on mine mind what caused it... the only thing we know of that was wrong was the timing belt tightened itself up to the point I couldnt twist it by hand I know this cause the camshaft to dig in but could it have caused the crank to twist that little bit to dig into the bearings... I just don't know..
I have been looking for a r33 GTR crank for a few weeks even looked at new items from Nissan who told me they would have to get one from Japan and couldnt give me a price until it got here... which sounded very unusual.
Keep the comments coming they are all helping me decide what path to go down.
The engine builder has been calling me a pussy all night for even considering abandoning the project this far into it...
To give you an idea of the damage:
This isnt a thrust bearing:
Edited by murrayis
https://www.sau.com.au/forums/topic/256060-what-to-do/#findComment-4415192
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
