as tittle says, been trying to find some pic's of how it's done..
i know the head is drilled and tapped and a fitting is put in then a return line is fitted and another hole is drilled and tapped to the sump..
where exactly is this done on the head...eg front, left side, right side, back ect..
where exactly is this done on the sump... front, rear ect...
any one got any pics to show us???
Any help much appreciated
Aaron
https://www.sau.com.au/forums/topic/256106-head-to-sump-oil-return/
hey man, from what i can tell it goes from the top welsh plug at the back of the engine, and down to the sump (un sure where) it goes under the plenum side so im guessing anywhere really aslong as its higher than all the oil so it works well,
got a pic, i took it from the oil control thread on this forum, may be some more pictures? would be worth a look?
heaps of people just fabricate a fitting to do the job. the return is then plumbed back into the sump on the plenum side becasue of the way the crank turns it helps to promote flow into the sump and not get sloshed back up from the crank.
Aaron
TUFFRX3 ,makes dash 10 and dash 8 press in fittings for the oil drain off the back of the head ,i have just brought some .no drilling needed ,just press it in and its done .i think he has some pix loaded in the for sale section
cheers
They really are not needed...
i have been told this to by my tuning shop is this true guys? im just building my engine now it has a greddy oil pump got a oil restrictor for head and trust sump extension do i need this return line?
cheers for the pic sly32...
what i read must have been way off, those welsh plug oil drain seem to be the way to go....
cheers to r33cruiser i'm definetly getting one from spool,
only $110 for the oil drain or $250 for the kit with the oil drain, speedflow fittings and hose...
Edited by vspec_gtr32
the questions is... i hear ppl call them just a bandaid fix to a problem... ne other comments on whether there really needed
not required...they dont drain anything substancial...they actually vent the sump on big clearanced race engines. On a properly built street engine they are waste of money, time and damage to firewall.
Notice two fuel rails on the picture supplied in post #2 (it was from another thread that i posted this picture in) Its a big $$ big clearanced racing engine.
Edited by DiRTgarage
cheers
And IMO, they're shit.
I have one on my R33... There is NO CHANCE you can ever fit the 90 degree bend whilst the head is in place, without unbolting the engine mounts and lowering the engine.
Once you have it on, it sits in the way of the heat hoses, and then, still sits hard against the firewall.
If I had my time again, I wouldn't do it.
Forgot to mention, I'm only running the dash 8... No idea how the people with Dash 10s fitted theirs!
Edited by MBS206
couldnt agree more.. sure there cheap.. but not suited at all.. the ones from spool are a much better option!
Well its been covered in past threads if he needed to find out why, but then its been posted in here as well since
i know it has.
i was just bringing to light ur yet again hypocritical ramblings. ur the first to pull up others on totally useless posts that have a suggestion but no fact to back them up.
just keeping u on ur toes :D
paul, im curious to know how the drain vents the sump. i have a rough idea of where ur going but if u wouldnt mind can u elaborate please
i know it has.
no fact? easy now :D
    • Yeah its bad eh. Ey! Watch your mouth. Yep, spot on. The rear's are always gone too though from brake checking. I had them perilously close to a tree that we had taken down. I think the tree peeps may have taken it. Either for a trophy, or accidentally.
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.         As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.      I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.    Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.            BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
    • Now that you mention it I can see those too. More subtle. The lighting and low resolution makes it hard to assess super well what's going on but what is visible is bad enough to pull the motor.
