not required...they dont drain anything substancial...they actually vent the sump on big clearanced race engines. On a properly built street engine they are waste of money, time and damage to firewall.
Notice two fuel rails on the picture supplied in post #2 (it was from another thread that i posted this picture in) Its a big $$ big clearanced racing engine.
so n1 pump, tomei oil restricter, 8ltr sump with baffle is enough?
i used to run N1 pump, tomei restrictor and stock sump with Tomei baffle 1 litre over filled.
never had an oil control problem and bearings were as good as new on pulldown after 3 years of racing.
Be specific Paul. "racing" Drag racing or circuit racing. Both disciplines require minute attention to the oiling system but curcuit racing adds other factors over and above what 1/4 mile work has to deal with.
Opinion is divided as to wether the drain back is a worthwhile mod or just a waste of time. The only definite in this whole debate is that it certainly wont do any harm by being there.
With that in mind I am more than happy to use it just on suspicion. It costs bugger all in the grand scheme of a build and, If the pro's are right it may save an engine.
Good enough for me.
Good enough for me.
great point for so little that extra insurance of doing it maybe worth it.
    • Interesting. My tuner said after the tune that my fuel economy would be better but it is the exact same from what I could tell even though my car was running rich before lol. How much do km do you reckon you get on a full tank of petrol on your commute?
    • A little follow up here on the ceramic coating.  We've had storms galore here and I've done a few ks, enough to gross them up  Consensus is that they didn't get as dirty as usual, the coating definitely repelled a little of the dirt and I think they kinda snowball. They get a little dirty and then they get dirty faster which makes sense. Cleaning them regularly would allow them to protect better.  Cleaning was a breeze. I tried first to just hose them off which, unsurprisingly, did nothing. But, making the wheels wet and then just wiping them over with a used but clean microfibre cloth was all that was required. I didn't need any cleaner at all, just water and a cloth. The wheels look amazing again.
    • Gave her a nice wash today and took extra time to clean off the tree sap and tar and crap. We have a usable garage now so she'll stay cleaner longer. Took a few snaps in some nice light afterwards.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
