Something to consider is the oil from your catch can will foul up the oil in the sump. I'd only do it on the track and even then only if your pushing litres of oil into the can (enough to drop the level in the sump).
Dude, blow by is anything that makes it past the rings i.e. oil, unburnt fuel, carbon, etc. That would be HORRIBLE for you oil. There is no reason what so ever to do this, other than hating your engine.
Agreed... also, if you're getting that much blow by that a catch can gets full in more than a months worth of street driving or 3-4 track days, your engine is well and truly shagged and/or you're pushing it too hard (too much boost perhaps?)
Vent the catch can.
The combustion gasses that push past the rings push up the oil return feeds while oil is attempting to run in the opposite direction and then out of your breathers.
Vent that sump and your problem is mostly solved.
Mine breathes zero; catch can is always clean. On the dyno the cans breather is clean running 1.6bar.
Setup the heads oil restriction correctly, vent the sump and you'll have no issues. providing the motor has been built well.
I've seen some 'well' built motors piss crap out of the cans breather.
Edited by TheRogue
If your catch can runs dry there's no need for the return to the sump then is there?...
For a street car with 5k service intervals this is a bad idea - if your racing the car and doing regular changes (ie after every track day) then its not a problem.
I find my catch can runs bone dry when drag racing and cruising around on the street but as soon as a corner is thrown in the can fills up. Apparently the mines baffles will help but otherwise I'l have to run a drain for track days etc.
Your missing the point.
Its primary purpose is to VENT the sump not return oil. Vent the sump and you won't have to worry about the pressure from the sump picking up oil and blowing it in to your catch can.
If your can starts filling with track use mines baffles are a bandaid/waste of $$.
Fix the problem properly; restrict the oil flowing to the head 'slightly' and vent the sump. Problem solved, or at the very minimum vent the sump it will make a world of difference.
Have a good think 'WHY' your catch can is filling.....
Sump pressurises due to combustion gasses leaking past the rings at WOT
Where is that pressure going to vent?
Its going to push up the heads oil return galley in to the cam covers.
On its way it passes oil going in the opposite direction picking up a little, heating and slowing the oil return.
As it slows the oil return more oil stays in the head excasabating the problem of too much oil in the head.
Combine that with constant RPM and you have oil pooling in the top end; the pressure blows out your breathers and starts to fill the catch can.
As I said; vent the sump to the catch can; run a nice 3/4" hose and you won't have issues. Make sure the catch can has baffles/steel wool etc to prevent any oil vapor soiling the cans vent and possibly having scrutineers pull you up on it if its bad enough.
The sump return as you put it is not a oil return; think of it as a sump vent.
The cam cover breathers will then do very minimal work if any as all the pressure will be released from the sump and not from the cam covers.
Edited by TheRogue
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
