Hey guys, i finally got my turbo n everything running correctly.. so i give the car a tune at first myself and after a week the whole tune turned rich again.. so i retuned it a few times then thought i may of been doing something wrong... so i called a few workshops and they just said the usual "oh it just needs a "proper" tune", so i sent it to be tuned n made 408rwhp on 19psi which wasnt to bad, so for the first few days it wasnt to bad and i runned a wideband on it... nice 14.7s on light cruise to 11.5's-11.6s on full boost..
So a few days later it started to feel abit slower and chewing a fair bit more fuel so i put the wideband back on it.. its now runnin 12s-13s around town.. n 10.9's-11.1's on full boost...
Is there anything else other than the ecu that could be causing this weird problem??
btw the ecu is a power fc pro
nismo 740cc injectors
sard fpr.. but the fuel pressure hasnt changed on it
Cheers
Jarrod
the stock o2 sensor might be messing with the afr's. what happens is you pull out the stock narrowband to fit the wideband, then tune it while the narrowband isnt reading anything. then you put the stock narrowband back in and it messes everything up again. my mate had the same problem with his pfc.
try unplugging the stocky completely and see where that gets you. your other alternative is to get your tuner to tune the car with the wideband that hooks into the rear of the exhaust and leave your stock narrowband in.
Turn 02 Sensor feedback OFF. If your tuner forgot to do that id be really worried.
Check out Paulr33's PFC FAQ to decipher which jap symbol means OFF and which one means ON.
Keep an eye on AFRs after that.
vacuum /boost leak..... cheack over cooler pipe joins etc. 02 sensor feedback wont effect anything other than cruise and light load, full throttle is derived purely from specific map values..
oh turbo could be on its way out, check boost curve.
Edited by URAS
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
    • Temu raptor, lol. At least the owner isn't your typical ranger danger lot
    • They definately are coming back around, so many GTRs coming through again with them.
    • Besides which. If you have a Haltech waiting - don't waste your time and effort and money trying to get the boost sensor. Just f**k the stock ECU off and put the Haltech in. Then you won't need the boost sensor.
