The turbobygarrett site is showing some more turbine housing options for Garretts GT3582R turbocharger , you'd think these were what was needed to get the most from these turbos but need a serious T4 flanged manifold maybe something like the cast HKS RB26 one .
Sadly these housings are single scroll but maybe later TS ones will get the nod .
http://www.turbobygarrett.com/turbobygarre...R_714568_10.htm
Cheers A .
If you open that link I posted originally it shows a picture of one wearing the T4 flanged turbine housing , in the bottom RHS of that page it gives you the part no's and A/R ratios too .
740902-18 = 0.63 a/R
740902-17 = 0.82 a/R
740902-16 = 1.06 A/R .
Cheers A .
Cheers A .
i can confirm that full-race does carry this. T4, 1.06 A/R, twin scroll. I am running it on my 26 now with a greddy T4 mani. i believe the TS turbine housing is made by ATP, but I am not sure.
i don't believe garrett makes a T4 TS themselves.
Edited by gawdzilla
I'd be interested to know how that combination works on an RB26 .
Cheers A .
Yes it would be interesting to compare the T4 1.06 to the T3 .78 GT35. IIRC Str8e180 was running the T3 .78 GT35 version on his RB26 and made nearly 400rwk's (with a few fuel issues). So you'd think the larger housing would be better still.
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
    • I’ll have more of a look into Recaros over the weekend. It’s taken me 2 days to figure out which Bride seats suit my application haha.
    • I am aware of their presence, but the product page looked like that conversion will eliminate the AWD capability. Fact remains it's kind of a hassle to send my oil sump halfway around the world and buying an extra one is expensive and unnecessary. Before I go hat route I'd explore more local options.    Would you recommend I just pull the engine and renew as many things as possible since I'm already having problems with some leaks? Would have to get an engine crane first though.
    • Are there any indicators that the vehicle is in limp mode?  Any dash light, or something.  Or is it just lack of acceleration?
