might chuck this up on calaisturbo.com.au unless anybody has any objections...i'm sure some people would be interested in helping out
yes you should i wanna see some nice vl's .
i'm coming.
instead of a caterer should just have a bbq to raise money or do both and make a flyer who cares if there is not enough food cos the more people the more money raised .
  • Replies 71
cos i know you guys are worried about not having enough food for everyone but the more people the better
i want to see heaps of cars not just 100 like the rest of the ones i'v been on
Edited by wannaslide
too easy i will keep you posted on numbers.. and if anyone else would like to put there hand up to meet at shell nudgee just mention that in your post so we know how roughly how many.
and going by google maps it will take roughly an hour to get to yamanto from nudgee, so to make the 8-30am departure from yamanto i think its best we meet at 6-45 and depart at 7am giving us plenty of time to get to yamanto meet.
Keen, be there in my evo if it goes ahead and i dont get stuffed over with work.
Edited by sinistagtst
We can get enough food as long as we have a estimate on how many are coming. It's not catering so much as it is food and drink vans.
ok its just i was reading the post on the skylines qld link and someone wanted to make up flyers and put in autobarn ect and the organiser said to just keep it cyber flyer so you can get an estimate for the caterer but i just think there is alot of people out there with nice cars that dont go on car sites
will be about 10-12 evos there from evo oz if not more
gret stuff mate. could you direct them to the thread to check out the new starting point. local police have directed us here to avoid roadworks. cheers.
Hojak, here's the details for the southside meet up.
Those keen.. details below,
Meet: Sunnybank Pinelands Shopping Centre Carpark (left hand side where nando's is)
Time: 7:30am meet and leave right on 7:45am and no later!!
prize up for grabs from me:
I dont think these are on the shelves yet :P
3 of them are up for grabs on sunday... 2 plain ones and one that will control an Ipod.
find me on sunday for info :/
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
    • But they do so for the other reasons to have a compressor bypass. It's in the name.
