hi folks,
my speedometer in my nissan hatch is out by something around 15 - 18 km/h according to my GPS.
so when I'm doing 100 km/h on the clock my GPS shows my 82 - 85 km/h...
(that is why I never got booked speeding, because I never had the GPS on... >_<
and I was wondering why a truck can overtake me when I'm doing 110)
how could I fix this problem ? is there any chance that this is just a adjustment
of something ?
thanks guys,
zee-german
https://www.sau.com.au/forums/topic/256172-speedometer-is-out-by-15-18-kmh/
Michael,
Where are you in Sydney?
There is a couple of reasons; 1. The speedo could be knackered. 2. Your tyre size might be wrong. 3. You could have a worn drive gear in the box and it is slipping. 4. The diff/drive gear combination is wrong.
This being said the service manual suggests only one (1) possible option and that is the speedo is faulty.
I'm in Sydney's south west (Campbelltown area) if you want another speedo, I'm sure I would have a spare laying around somewhere from when I had mine rebuilt by Jenesis.
Cheers, D
If the odometer is correct, then all the gearing (tyre sizes, diff ratios) are correct.
The speedo works off a magnet spinning inside a metal "cap". A spring controls the "cap" from just going on and on. With age, I reckon, the spring loses its tension, and lets the "cap" rotate further than it should, thus indicating a higher apparent speed.
hmmm, sounds good... but it shows me a slower speed... so the other way round.
I know that I have the right tyres on the car. right size ect... just changed them a few months ago.
and the gearing should be ok as well. it is an auto transmission, it works fine and solid.
Michael,
Cheers, D
hi,
I'm on the other side of the city (north sydney, neutral bay)
I bought this car of an old lady 16 months ago with only 116.000 km on it.
and it drives well... engine and auto sounds solid, just changed the injectors and the waterpump.
but my speedometer problem is since I have this car.
No, it's not (the other way round).
You said the speedo shows 100 when you are actually - according to the GPS - doing 85. So the spring isn't retaining the speedo needle enough. The speedo is indicating a speed HIGHER than actual. (which is what I believe I said the first time, perhaps not so succintly)
I have always gone by gearbox ratio, diff ratio and tyre diameter with tacho reading. So in a manual you can work out exactly what speed you are doing, but in an auto you have to decide whether the torque converter has locked up.
There are places on the freeways where you can clock time against the actual tyre diameter will drive you at a predetermined tacho indication. But you must have an accurate tacho.
My new Ti hatch in 1984 was pretty close to 50 clicks per 1000. So about 2000
Hi, To check if your speedo is working properly go find a 5km odometer check and record how far your odo shows over the 5k's (do the test at the posted speed limit as speed has no relevance with this test) - if the odo shows around 4.2 k's or even under 4.5k's then the problem is unlikely to be the speedo - if the odo shows between 4.9 & 5.1ks then the speedo is likely to be the problem. If the speedo checks out, then you are looking for a component in the gearing so the speedo cable is not spinning at the correct number of revs/km eg speedo drive, the diff changed to a lower ratio and the speedo drive not changed to suit, or wheels/tyres are not standard but i doubt that as the wheel/tyre combination would have to be a lot smaller than standard to make that much difference - most of us put wider & higher tyres on which reduces the revs per km and this causes the speedo to read slightly slower relevant to actual speed ie more accurately - which is why most speedos have a 5% fast read built in ex-factory. If you need help with correct speedo drive ratio i would need to know your diff ratio & tyre size. Cheers, Tel
thank you guys for all the answers ! I will check it with the 5 km test..... :-)
"My new Ti hatch in 1984 was pretty close to 50 clicks per 1000. So about 2000"
What a hoot old man, my new 180B SSS in 1973 used to get 20mph/1000rpm in top (4th) so when I was sailing across Mooney Mooney bridge on F3 at 6750rpm, I sorta understood the fowl looks I got from the boys in blue doing radar duty. lol
Cheers, D
Sorry for hijacking your thread temporarily
my speedo is stuffed with the vl gearbox.
the speedo drive is for 3.45 gears and i have 3.9.
i just work out how fast i am going from the RPM's.
100kmh is 2500rpm in 5th and every 500rpm is 20kmh.
speedos are always wrong from factory.
only shit thing is it clocks up klms quicker on the odo
but who cares. just buy another dash.
My first RMR30Ti had 600 on it when I gave her a decent burial. Changing the speedo is (illegal) a bit of a waste.
"Changing the speedo is (illegal) a bit of a waste".
Not if your old one is broke, it's not.
In NSW the annual rego checks require an odometer reading on the inspection slip, so the RTA knows wether the speedo has changed and or been repaired.
My PNV when it goes on the road will have a Jenesis 260kph speedo with ZERO on the clock & a 9000rpm tacho and that wont be illegal.
I suppose it's a bit diferent for these backward states that don't have regular inspections eh?
Cheers, D
Shhhhh, I like these backward states that don't have regular inspections.
otherwise my turbo conversion may never get done, or my aftermarket ECU, wouldn't past muster (emissions), but then again, I have never looked into what is or is not illegal.
Nigel
Cheers, D
I thought as much, its more illegal to have an odo that is not working.
I think we should have regular inspections. Get all the shit heaps off the road.
Maybe not every year but every three or five years. You see cars driving around
with smashed lights, rust everywhere, some real junk boxes.
skybt1, might I suggest you change the drive in your gearbox to the correct one - the RB30E gearbox should take the same pinions as the old FS5W71B/3N71B/4N71B that the car came with.
Dennis, if you were doing 6750rpm (as indicated on a 1973-accuracy tacho!) in a stock 610 SSS in 4th, then it must have been downhill :blush:
(and you must have been out of your mind)
I've got a 4.375:1 LSD in my DR30, but in order to get the speedo correct (within ~5%) I've had to fit the 4.625:1 speedo drive. A combination of slightly shorter tyres (225/50/16) and a 25-year old speedo have resulted in extra compensation being required to get things right.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
