For sale: Y31 Nissan cima ( brought from this forum as not working item some of you may remember)
Engine:
VG30DET
Fresh gaskets from inlet manifold up and rocker covers
New sparkplugs
New coil packs
3inch exhaust from cat back with cannon
K&N pod filter
Exterior:
Full VIP body kit unsure of brand
Cracks here and there nothing major just body kit has seen better days
Front LH guards bent but i do have replacement guard
new window moulds (one that goes between the front and rear window)
Weds 17” rims
Stock grill as well as aftermarket grill
Interior:
good condition everything works (reclining back seats, heaters, climate control)
Past owner painted all the inserts white to fix this i have got all stock replacement wood grain items the two back covers for the ash tray are in a diff style of wood grain how ever but hard to tell unless you look directly at it.
Item Condition:
It is Alright condition im not going to say it is in the best condition but it is a easy fix i just dont have the time to fix it as my other car has gone in to get fixed the car is driveable but will need new front brakes for RWC and i’m unsure of what else it needs there are no leaks in the engine bay that i know of as i have repaired what ever was leaking and engine is running airbags work from what i have tested but i have not tested them to 100% (holds air, and also lets air out unsure what else to test)
Extras:
Juction produce bonnet mascot
Juction produce side lights
Juction produce Gold mirror hanging thing
Price and price conditions:
Asking $3000ono and after a urgent sale as I now have no car and no time for two projects and I would rather keep the evo then this >_<
May also consider Swap for other car. Please e-mail pics and a small description of the car.
Contact me on 0431523443 (name is Robert)
Or [email protected]
Or via PM
Car is located in Cheltenham VIC
Pictures can be found here
WWW.TEAMKINTAMA.COM/Y31
Sorry about the link but all the pictures are big so you can zoom in and what not on things you want to see
https://www.sau.com.au/forums/topic/256174-y31-cima-vic/
Car is running and driveable could be driven home but i will not take any responsablity as brakes are way below the min amount
price is $3500ono as other car i wanted sold :) so no longer a urgent sale
https://www.sau.com.au/forums/topic/256174-y31-cima-vic/#findComment-4427856
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
