updates: should be confirming attendance and support from Nova 91.9 and SAFM soon, along with aTruck driver who is donating his truck and time to collect any non-cash items and drive them himself to Victoria. So clothes, non-perishable food items, bedding etc will be welcome donations on the night.
  • Replies 139
Posted Images
sounding good so far. Hopefully a couple of places i talk to once i have a copy of the letter will be willing to help also. Steve, feel free to pm me with some of the infoyou have been giving to places to get them on board.
excellent, thanks bats. so far we have a couple of dyno runs being thrown in by Graham West, Jun style kit for R33, and hoping to get more once the letters are finalised.
hahah thanks Chris was about to say i went and Saw Extreme today and yeah Brett West is more than happy to help out
need to catch up with marvey tech and simon @ morpowa because John wasn't at the work shop i just kept going
good job Nathan thanks for all you input as with everyone else Kane and co.
Ok Guys here is the document you can take to prospective business traders i think all the information is covered, the missing blanks are to be filled in by your selve like
Dear Auto Barn, and the RSVP is your mobile number unless they tell you when you show them the letter they will defiantly come, and the last blank is for your name.
thanks for everyone's help and support and we will see those helping on friday at villies
if you have trouble with the pictures not being down the bottom of the page let me know as Nene said hers are at the top of the page
Has anyone already organised the Red Cross to be in attendance?
Red cross said they will be sending representatives on the night with posters and tins for donations. The Salvation Army I have been told will also send 2 reps.
so we have got quite a few people on board now
great to see that and a nice way of putting SAU in the (so to speak) good books
awesome work fellas....i will definately be there
People are doing fantastic work here!
Just a suggestion...
Perhaps we should contact Woolworths/IGA/Coles to see if they want to donate some food platters (nibbles) on the night?
Also, Is the Mawson Lakes Hotel equipt with a PA system for the auction?
Will someone from SAU be the MC for the night? (to do auction, speaches, welcomes, thankyou's etc)
If this is stuff thats being discussed at Villis then just tell me to shhhhh. :banana:
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
