[20th Feb] Victorian Bushfire Fundraiser Cruise
not organised by Antilag, it was a event repost for Kylie (stroppy 1) from tunedwa iirc..posted on most car club to raise funds..
anyways, hope to see you all there, should have a section of SAU cars parked up.
  • Replies 141
Posted Images
I cant be home for this one. Apart from adding much needed support to the victims of the fires this is an excellent opportunity to demonstrate to the wider community that we are not all "hoons". Good luck with it and keep it safe
kerr im heading down for about 740 with some ppl we can try sort some room for sauwa also i was speaking to some ppl from another forum last night and "supposeably" today tonight is going to be there filming to show we r not all hoons that some ppl r just car lovers
is anyone else pissin there pants coz there so excited about this???
lol... it should be good for sure Rick :)
Come over and say hi tonight. I'll be there. Been meaning to catch up with you, but there have been many things getting in the way lol
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
