Originally posted by INASNT
Ben
so you guys only got to 297rwkw!!
y not do a full engine rebuild and go for over 400rwkw???
What for? The point was to show what you can achieve without a full engine rebuild. In any case, with 297 at the wheels it was already becoming fairly compromised as a road car. Personally I think about the 250-260 mark is ideal for a RWD car this weight, unless you are building a car for drag racing only (which wasn't my intention). We may build a car specifically for drag in future, but if we do we won't start with something as heavy as an R34. More likely an R32.
Originally posted by ido09s
so all the engine mods are gone now....... still not a bad price though for an R34
Actually it still has the Tomei cams and HKS metal head gasket, which lets it run 0.8bar on the standard computer. Combined with the exhaust it goes surprisingly well. The handling is pretty special too.
i wouldnt pay that for a car i know has been flogged half its life. Im sure the engine after running close on 300kw wont be as clean as lots out there.. but thats my opinion.
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
