hrm...okay dave...
goodluck finding a *performance* car that has not had its arsed flogged...thats what they were built for mate. if you wanted to buy a car that hasnt had its ass flogged, you should start looking at bmw 318's or magna's or something?!?!?
and btw. knowing that this car IS capable of 300kw is bloody great! I know that the engine is running as it should be!
Just to update, the car is still for sale.
It's worth noting that the car made 230kW or less for most of the time that I had it. It only did about 3000km or so with the big turbo set-up. 300kW was actually a conservative tune, if we had really pushed it there was more power to be had. The engine is in excellent condition, as any test will show.
As for the camber question, I believe it was around 1.25 degrees negative.
Originally posted by GSR 13S
Any chance of the wheels being sold separatley?? I really want to get a set for my R
Cheers
You are better off with 18x9 at both ends, my set are 8-inch at the front and not the right offset for a GT-R anyway.
Ben,
Any specific reason y gtrs run equal width wheels front and rear?
Somone on the forum mentioned it was due to the need for the wheel diameters of the front and rear wheels to be equal for the attessa system to function properly. (Front and Rear wheels need to be travelling at same speed)
But i would imagine...with careful calculation of tire profiles, equal diameters would still be achievable, while allowing for a wider rear tire (since a gtr is rwd most of the time?)
Yes, you do need equal rolling diameters. I have seen GT-Rs with different-size wheels front to rear, but since the guards are designed to suit same-size at both ends, why not fit them? Unless you make the rear guards much larger, you will be compromising the front, rather than improving the rear, if you see what I mean
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
