There should be a little lever on the lock mechanism inside the boot (on the bootlid). Flicking this lever will prevent the remote release from opening it (they work a bit like a child safety lock on back doors of cars)
https://www.sau.com.au/forums/topic/25624-locking-the-boot/#findComment-544268
when you open the boot look down, you see the lock! move inside the boot and you see the plastic cover over where the lock is!! there should be a hole in it, pull on the hole and the littl;e door will open up, just inside is the switch, right near where the boot cable meets the lock!!
https://www.sau.com.au/forums/topic/25624-locking-the-boot/#findComment-544487
