ok so here it goes, car is series 2 r33 DE+T, with mods in my signature,
took car for a dyno run to make sure afr's and ping was under control after getting a remap, didn't finish the dyno run as the coil packs were giving up and the car was breaking down...
car ran good after that jst misfiring a bit underload,
next day start the car and it sounded like a wrx, shuddering on idle, very lumpy,
i have read about this problem occuring when the coil packs are gone,
so i wanted to limit the problem to which coil it could be so i can get a second hand one till i get splitfires or JJR ones,
i took the cover off and connected everything back together, started disconnecting coils to see if there is any change in the engine noise or exhaust note
i did it to all 6, when i did it to coil 1 and 3 there was no change in engine noise or exhaust note, so i thought it could be these coil packs
changed the coils around with another two, and did the same test and still the same thing on 1 and 3
so im asking, what could be the problem, is it an injector problem, how can i check which injector is faulty, could it be a coil lead problem? or is my engine F#$$D
and btw just changed the spark plugs to BCPR7ES 0.8 gap, same day as dyno,
could it be a spark plug issue, might take them out tomorrow and have a look, what should i look out for?
compression test might be the last thing i do if nuthing else comes up,
any other opinions,
thanks
yes a faulty injector could cause a simillar problem.
but before we try and start to come to all sorts of conclusions....
firstly, were sure the Ignition leads are plugged in properly in sequence?
secondly, by any chance...did you wash your engine bay after the mods or overhaul?
ive had a same problem in my TT supra...i washed the motor and water got into where the spark plug sits...and caused WRX sounds....
ye they all plugged in correctly, you cant really stuff the order up, its a no brainer as they only have so much wire running out of them,
nah haven't washed the motor,
pretty sure i have read that the only other thing it could be is injectors leaking or something, anyone know how to test injectors without taking them out,
I just had the exact same problem with my RB25DET and it ended up being a mix of shagged fuel pump not holding pressure and blocked injectors.... Pressure test ur pump 1st. It might flow ok but pressure test it to.U might find the electrodes on ur plugs have turned white from it running very lean under load. Also wouldnt hurt to check ur fuel pressure regulator to see if the diaphram hasnt broke.
Edited by FordyR31
take all the plugs out, unplug injector loom and crank the motor, if it's an o-ring you'll soon know!
so basically, take all plugs out, unplug the coil packs as they may spark, and unplug the injector loom,
and i'm guessing i watch out for petrol in cylinder 1 and 3, and it would mean that injectors are f*ked, as they are leaking,
will give this a go tomorrow,
and then clean out the petrol with a rag,
correct so far?
thanks man
the pump is a bosch 023 from ebay, how do i pressure test the pump?
thanks
correct so far?
thanks man
will need to unplug coil packs to remove them, and if it's a leaking injector fuel should come out from the spark plug holes,
had this happen to fellow members car not long ago, was a cracked o-ring
have your injectors been touched at all?
thanks
Mine was a bosch 040 from ebay, a ford dealer in melb actually but bought on ebay. I dont know exactly how to pressure test it coz I didnt do it but I would think maybe putting a Fuel pressure guage after the fuel pressure reg, or just b4 it after the fuel filter and priming the pump with the ignition on???? Please if thats wrong someone say so b4 he does it.
New fuel pump, pressure reg and cleaned injectors and my car doesnt miss a beat on all 6 cylinders and goes a little better than ever.
the injectors haven't been touched since the conversion,
il try the injectors first, and then get more info on testing the fuel pump, all i can say is that i can hear the fuel pump priming nice n loud and got it installed at a reputable shop..
Just to add my pump was installed by Pro Maz in Melb and It was priming and flowing fine but was failing under pressure. Just because u can hear it and it flows ok in a flow test it doesnt mean it's holding pressure. Check everything in the fuel system u possibly can I'll link you to my thread, I went into a fair bit of detail of what happened and what was tried/suggested. Might be able to help u out a little.
http://www.skylinesaustralia.com/forums/S2...Lo-t252361.html
My car ended up having quite a few issues with it but the main problems that stopped it running were blocked injectors, fuel pump let go, hole in the diaphram in then fuel pressure regulator.
ok so in the last few days i have changed
injectors with the whole rail for another set of second hand ones,,, and no change
coilpacks with another set of second hand ones.. bought them from another member and told they were good nick... and still no change
what are my other options... thanks
nah no compression test yet... i dont want to find out bad news lol...
il check my spark plugs tomorrow to see if they are in good nick, but i just changed them like last week..
il see a few mechanics that are open for some ideas... maybe go to status if they are open
if the car was running very rich like 9:1 or 10:1 could this f**k up one or two of my sparkplugs.. and therefore caus the car to run so shyt..
caus i changed the sparkplugs and put it on a dyno... there was a leak in the cooler piping and it was running very rich... fixed that then the coilpacks were breaking down and didnt have a proper power run... just a thought... we shall find out tomorrow...
Is it an Ecu issue ?
you were on the ball man,
took it to Trent at Status today and he had a quick look and told me to swap it with the NA ecu to see if idols properly,
and to my amazement it did, afterall it was just an ecu problem, the coil on cylinder 1 and 3 were not working, but with the NA ecu they are
now just a matter of getting another turbo ecu with the remap from toshi
thanks to everyone with their suggestions
never crossed my mind it would be an ecu issue
getting splitfires and back on dyno soon
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
