ok i just seen that my inner front cv joint boot is perished away and i can now see the bearing, anyone no where i can get a replacment asap.
i looked at these boots that split apart so you dont need to remove the axles to fit, but not too keen on em but if anyones used em and they seem ok ill use whatevas goin.
https://www.sau.com.au/forums/topic/256272-cv-boot/
This guy sells the complete cv joint for less than Nissan charges for the boot. He may also be able to supply the boot only. Send him a question quoting your engine no and other details he asks for and ask if he will post to AU. (if he doessn't but he has the item I could get it for you and post it but i am hoping he does because a number of other members have indicated interest). http://www.trademe.co.nz/Trade-Me-Motors/C...n-201624551.htm
https://www.sau.com.au/forums/topic/256272-cv-boot/#findComment-4417885
  • 7 months later...
Hey Guys I have just replaced my front boots with local Kelpro units at $15ea.
Part no':
Inner: CIB-228
Outer: COB-057
Only point I would make is that there is not enough grease supplied for the inner if you ask me, so grab some extra.
https://www.sau.com.au/forums/topic/256272-cv-boot/#findComment-4849949
Part no':
Inner: CIB-228
Outer: COB-057
how would you rate the difficulty of the job mate? i've never done cv's before, but will probably be looking at it in the not too distant future ;)
Edited by pyro-ns
https://www.sau.com.au/forums/topic/256272-cv-boot/#findComment-4850408
Ok Guys its all pretty straightforward to do, probably the only special tools you need are circlip pliers and a vice is handy.
Firstly remove the shafts, there is a good description here on pages 10 & 11
http://www.scribd.com/doc/4964854/GTR-Engine-Removal
You will also need to pop out the cup that is in the diff housing, a couple of large screrwdrivers should do the trick (carefully)
Next I usually cut off the old boots and give the shafts a good clean ready for new grease & boots.
Below shows the drivers side, the passenger side should be similar (I only needed to do my drivers side, but the passenger side looks to be exactly the same procedure). :whistling:
You need to remove the circlip that holds the bearing assy (part A) to the shaft (part B) in the pic below.
Remove part A from the shaft and you can now slip on your new boots.
Replace part A and circlip (grease the splines) and complete assembly as below.
This is just a matter of packing the bearings and cup with grease and fitting the new boots. Make sure there is no grease on the part of the boot that will be clamped to the shaft & cup (under where you tighten the stainless ties).
Tighten the stainless straps by stopping them rotating with a flat blade screwdriver whilst gripping the strap with locking pliers. Bend the strap over once, bend down the tabs to keep in place, and bend once again over the tabs and cut off the excess.
Reinstall the shaft in reverse order of taking it out.
I think this covers it if you get stuck on anything let me know.
Hope this helps.
Good Luck,
Jon.
  • Like 1
https://www.sau.com.au/forums/topic/256272-cv-boot/#findComment-4864108
Thanks for posting that up mate :(
So after doing this im going to need an alignment by the looks of things yeah? When i got the outers on each side done previously at a mehcnaincs they said they do it so it didnt need an aligntment.....
Ideas?
https://www.sau.com.au/forums/topic/256272-cv-boot/#findComment-4865006
Thanks for posting that up mate :P
Ideas?
In theory it shouldn't need an alignment as you're not actually adjusting your tie rods, just disconnecting them to remove the shafts and putting them back. Unless you have some really worn components, they should bolt back up in the same position they were in.
However I reckon it's always a good idea to have things re-aligned when you've done any suspension or steering work.
https://www.sau.com.au/forums/topic/256272-cv-boot/#findComment-4865779
Well im preping to do this in the next week or so. Wouldn't mind doing it tonight but I need to use the stag to go jetskiing tomorrow so might noit be a really good idea incase i dont get it back together... dont see why i wouldn't though..
Went to see my local repco for the boot. Qoted the Kelpro CIB 228. He matched it to a Repco unit they had in stock part number 100-039. Comes with straps and grease. Cost me $13.60 with my trade card.
Will post up how I go and might ask the woman to take photos while i do it so i can make a how to however i dont think shell like the idea of it.
https://www.sau.com.au/forums/topic/256272-cv-boot/#findComment-4870992
Good luck with the boot install. Let us know how the Repco unit fits, it's good to have alternative boot options that don't cost $100 or so each from Nissan!
https://www.sau.com.au/forums/topic/256272-cv-boot/#findComment-4875746
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
