Well after almost 12 months since the last one, i've just had machined 2 new billet girdles. One to suit a rwd RB and another to suit the 4wd rb30. This time it replaces the entire std girdle.
Testing will be carried out on an engine in the next 2 months.
https://www.sau.com.au/forums/topic/256351-billet-girdle/
they look the goods....but the real question......tell em the price son.
wont know exact price until i get the invoices, as soon as i know i'll post it up
Very nice work! what material did you make it from?
thanks. material is 7075
https://www.sau.com.au/forums/topic/256351-billet-girdle/#findComment-4418153
going to be a stupid question but i want to know lol
whats the advantage of this over a stock rb30 one with a 4wd adaptor plate? (for GTR)
*puts flame suit on*
the 4wd adapter is only a 'spacer', its does not tie into the girdle to the block.
this girdle ties everything together, the block, crank and girdle
https://www.sau.com.au/forums/topic/256351-billet-girdle/#findComment-4418640
Do you forsee any issues with the difference in themal expansion between the block and girdle?
Yes the thermal expansion rate of alloy is greater than that of cast iron, but i dont see it as a great threat to the integrity of the girdle.
When the alloy heats up, it will expand at a greater rate than that of the block, however there isnt any real where for it to expand to, it will actually give a tighter lock into the block.
This is one of the observations we'll be making with the test engine.
https://www.sau.com.au/forums/topic/256351-billet-girdle/#findComment-4419127
i think adriano was thinking the same thing i was. My concern (possibly unfounded) is that differrent thermal expansion rates would play with bearing crush... and or centricity
Edited by URAS
https://www.sau.com.au/forums/topic/256351-billet-girdle/#findComment-4419240
Beautiful!! :) Is there any reason you couldn't make one in steel, given a big enough lump of material? Here in the UK it's very hard to get decent line boring and honing done, they often end up a real pig's ear. How do you go on in Oz?
https://www.sau.com.au/forums/topic/256351-billet-girdle/#findComment-4421420
Beautiful!! :( Is there any reason you couldn't make one in steel, given a big enough lump of material? Here in the UK it's very hard to get decent line boring and honing done, they often end up a real pig's ear. How do you go on in Oz?
Cost. Itd be more expensive to make one from steel due to the time required in machining. Also steel isn't all that good for dampning harmonics, and add to that the massive weight of the thing.
We dont have a problem with line boring/honing if you use the right people.
https://www.sau.com.au/forums/topic/256351-billet-girdle/#findComment-4422122
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
