Engine:
N1 24U block (own modifications done) race prepped
Fully balanced and blue printed
Chemically cleaned/crack tested and washed
Torque plate bored honed & decked
All new welsh plugs
Tapped oil gallaries
Fully balanced/detailed crank and grub screwed
New Ross harmonic ballancer
Race prepped crank gurdle
Shot peened/prepped standard rods with ARP bolts
Full ARP bottem end stud kit
Ross Racing forged pistons (ceramic coated)
ACL race bearings mains & rods
N1 oil pump (modified)
N1 water pump
Genuine Nissan gasket kit
Fully port & polished head
Match ported intake
Brass valve guids
Standard valves
Upgrade valve springs
Standard cams
Greddy adjustable cam gears
Gates timing belt
New genuine exhaust studs & nuts
Garrett GT3082r .82 turbo polished front cover
Braided oil lines
Speedflow fittings
Tial 44mm wastage
Ebay spec manifold modified
Greddy twin entry air intake pipe
2 x RB25 Air flow meters
4" dump pipe
4" catback exhaust
4” high flow ballistic cat
600x300x115mm Greddy style intercooler
Custom PBR clutch
Nismo lightened flywheel
Nistune ECU
Sard fuel pressure regulator
custom fuel rail
r33 gtr lift pump
044 fuel pump
2L surg tank
3/8" Aluminium fuel lines
Heap of speed flow fittings & push lock hose
Sard 700cc injectors
Alloy dual core radiator
Silicone radiator hoses
Silicone heater hoses
Exterior:
Full colour change
18x9 18x10 roh drift r's
carbon exhaust shroud
carbon top secret bonnet painted
genuine gtr front bar and gtr grill
rear drift lip
nismo b pillars
tein coil overs
Inerior:
gtr dash cluster
autometre boost guage
hybrid boost controller
greddy turbo timer
https://www.sau.com.au/forums/topic/256366-final-stages-d/#findComment-4420116
