I've recently pulled the CVT out of my 2000 Nissan Y34 Cedric as it had some serious amounts of small gold coloured and metal particles in the sump not to mention shockingly dirty fluid.
According to the blokes at CVT.co.nz you need to be a trained professional at rebuilding these boxes and they want $6-$11,000 for a rebuild/repair because they are one of the only english speaking extroid CVT experts in the world. Obviously I can buy a wrecked CVT equipped Gloria/Cedric in Japan and ship it over for a lot less then that, so i decided to rip the box apart and find out exactly what fails and have the parts replaced/replicated if the expensive is considered reasonable.
The box in question is the RE0R04A 6 speed CVT which will be very similar to the 8 speed found in the GT8.
I started the strip down last night and all i can say is its a nightmare. The amount of different sized bolts and clips/gears are scary. I've done the best i can at logging where all the bolts go and document everything with pictures so hopegully she'll go back together fairly easy.
Since I have only worked on it for about 2 hours (including an hour to take the box out) here are some pics for you to have a gander at.
I will provide more pictures/information as it comes to hand.
Cheers
Ben
cool. it will be interesting to see how you get on. no doubt a lot of your work will apply to the GT8 trans as well. since neither is really an 8 speed or 6 speed both are just a CVT with different 'shift' programming you can utilise giving a number of set ratio points.
I honestly have no idea what wears in them but it should look like this inside as I understand nissan use the type of CVT with a belt drive with 2 variable size pullleys. which is probably the most common type. there are a few potential spots though I can think of off the top of my head.
and here's a good little gif for those who have no idea how they work.
  • 2 months later...
  • 5 years later...
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
