Well, its time to sell the Skyline after owning it for about 3 years. Car has always treated me good and has never in the 3 years i have owned it given me any significant mechanical problems at all, except for coilpacks and damn car alarms! which has since been changed 3 times and is now all good.
Reason for sale is my partner and i have recently bought a home and we need all the money we can get for the house.
Located in southern suburbs of Adelaide.
Very tuff road/street car, has a lot of presence on the road.
***DETAILS***
- 1993 R32 Skyline (Type-M)
- 134,000 kilometres
- Gunmetal Grey colour
- 2nd owner in AUS
- Mechanically it is in great condition, the gearbox is in perfect condition, no crunching or syncho problems, those who have driven it will agree.
- Handles like its on rails, great turn in and grip, the only down side... you feel every bump in the road (However the coilovers are adjustable and this problem can be rectified if neccesary)
- Currently registered
***MODS***
-Suspension/braking-
- Tanabi sus-tec pro front coilovers (Adjustable height, damper, body etc)
- JIC magic rear coilovers (Adjustable height, damper, body etc)
- Adjustable rose-jointed castor rods (Set to about 8 degree castor)
- Front and Rear whiteline thickened sway bars
- ZENITH Solid alloy rear cradle bushes
- ZENITH Solid alloy steering rack bush
- Large GTR type front strut brace
- R33 Lower control arms for more track and camber (Camber currently set to about -3 degree front)
- Braided brake lines
- Recenlty installed Lucas full-metal brake pads
-Power/driveline-
- Boost controller (Currently set to about 11-12 psi)
- 600x300x75mm Front mount intercooler
- Full 3 inch exhaust with front pipe/dump pipe
- Re-mapped ECU by Sam Cornell
- Larger Walbro fuel pump
- Heavy Duty Daikin clutch (Feels perfect, not rough like a button clutch, and has never slipped)
- Metal 'hot pipe' by Exhaust tech (Metal pipe inside the rubber induction pipe to prevent it collapsing under boost)
- Greddy Blow Off Valve plumbacked into system (legal) and now creates a very nice flutter sound
- Pod Air filter
-Cosmetic-
- GTR body kit, side skirts, wing and front bar etc
- Pumped fiberglass front guards
- Pumped and rolled rear metal guards
- 18 inch G-max dished rims, 8.5" front, 9.5" rear (Unsure of exact offset, but pics speak for them selves)
- Tinted windows
-General-
- 360mm Black NARDI Steering wheel
- HKS pillar mounted boost guage
- C's Short shifter
- White vision H4 XENON headlights
- Cyclops Car Alarm and immobiliser (Keyless entry, central locking etc)
- Some 6" front speakers and 6x9 rears
- Also comes with 25mm bolt on spacers that are on the rear in the photo's below, currently not on the car for legality reasons
I'm sure there is also a lot of stuff i have forgotton, if you have any questions, just ask.
***CURRENT PROBLEMS***
- Crack on drivers side of front bar, toward the ground
- Small crack on passenger side headlight due to small stone flicking up
- Passenger side power window sometimes only works from divers side controls (Passenger cannot always put it up and down from thier side)
- Drivers side floor carpet starting to wear away, can be fixed with floor mats
- Interior air-con vents plastic surround has cracked
***PRICE/CONTACT DETAILS***
- Currently looking for $14,000 or nearest offer, have spent much much more on it.
- PM me, or contact me on
Cheers, Ryan
***PICTURES***
- I have tried to include a lot of photo's to give people a good idea of the car
https://www.sau.com.au/forums/topic/256376-1993-type-m-r32-skyline-14000-ono/
i must admit that is one dam nice 32. one of the better ones in adelaide thats for sure.
hope you get what is deserved as it reflects the right price.
  • 4 weeks later...
    • Awesome mate, sounds like an awesome car! My 33 has the 400R/Nismo front and rear bumpers and side skirts. They're in terrible condition though so I either need to fix them up or toss them and get new, standard bumpers and skirts. I wish the Nismo stuff was FRP not fibreglass as they're always one nudge away from complete destruction!
    • Thanks mate 👍 The car was brought into the UK by a USAF mechanic until he was stationed back to the US, one owner later I bought her back in 2009. Luckily the only corrosion was on the sill seams, so once taken back to metal and treated and sealed all ok, I then undersealed the car myself and check yearly and treat any corrosion which to be honest is zero. She's garaged most of the time and hardly ever driven in the rain, but as you say most are rotten unfortunately, I was lucky in finding her as she was and still is in excellent condition.
    • Stunning car.  Looks amazing!  You're in the UK?  How the hell do you stop your car rotting away beneath you?  British cars are the WORST I've ever seen in regards to rust.  Some of the cars SR Autobody have done are borderbeyond saving.
    • not a date code? or a foundry code?
    • I have up to date pics of the engine build and turbo conversion over on my instagram @skpro_jects if you want to take a deeper look.   Basically the exhaust manifold is straight bolt on and the ports match (they arent any smaller than a 25 or 26 head).    the intake ports are different shape so the 20/25det manifold will bolt up but wont match properly or seal. You will need to port match using the 25det gasket as a stencil. Personally i ran the entire stock 20neo intake setup and have configured the swirl valves and torque valve to work based on my custom parameters to help with off boost response and spool. But this is using a standalone aem v2 ecu. The stock 20det ecu wont be able to control them.
