Calling T3 Experts!!! I've scored a T3 adapter for my boosted Toyota Starlet which is basically a 1.3l fwd shopping cart with a bit of poke! :D [/size] What i'm chasing is a bit of info on the T3 flanged turbo's.
Is there such a thing as a 'smallish' T3 which would be best suited to my 1.3L 4pot fury? :( The guy how had the adaptor previously was running a KKK26 which i believe is of some sort of euro monster. The adapter has a ex-gate to the dump.... Any thoughts or general comments appreciated!! :thumbsup: Thanks for reading!! Steve :)
Edited by rikjames
https://www.sau.com.au/forums/topic/256389-t3-question-for-myerrr-starlet/
Calling T3 Experts!!! I've scored a T3 adapter for my boosted Toyota Starlet which is basically a 1.3l fwd shopping cart with a bit of poke! :D What i'm chasing is a bit of info on the T3 flanged turbo's.
i have seen people turbo briggs & stratton engines on you tube, maybe message one of them to see what turbo they are using.
Is there such a thing as a 'smallish' T3 which would be best suited to my 1.3L 4pot fury? :thumbsup:
Hey man - one of my mates has a EP82 which he was running SMALL T3 turbine side (~.42a/r or less) with a 60trim T3 compressor wheel.... probably along the lines of a Skyline T3 turbo smaller than an R33 one though he has always been a bit vague on it. I will pick his brain and come back, but I'd guess it was in the territory of an RB20DET turbo.
It drove remarkably well - felt much more solid than you'd expect, a little laggy but in such a light car it didn't seem to hinder it and once it passed 4000rpm the thing pulled HARD to redline. The thing touched flat 13s (or high 12s?) on >200,000km stock internals and was a complete hoot to drive like that.... its got a bit more of a serious since then though.
Thanks Lithium!
A mate has a R33 and he has a spare ebay bought brand new T3 (not sure if it's a T3/T4 hybrid) - Are there specific R33 and R32 T3's?
Do both run a internal gate?
....and who's your mate with the starlie? :D
Edited by rikjames
Do both run a internal gate? ....and who's your mate with the starlie? :down:
All the Skyline turbos are internally gated, the R32 has a smaller turbo than the R33s. The Skyline turbos probably aren't a good option come to think of it as you'd really need to run a bit of boost and they are effectively glued together. An R33 one MIGHT be ok, how much power are you after or how much boost do you intend on running? I'm not sure if you are talking about using the stock R33 turbo or an eBay upgrade, I'd warn against going down that path.
I asked him about it and he said it was advertised as being off a 300ZX, probably a VG30ET turbo - and he put a .3 turbine housing off a LD20 turbo to bring it on quicker. He reckons the LD20 turbo is a good base but the compressor wheel is a bit small.
I can see the logic in turbocharging a 1300 twin cam but dunno about with a "T3" flanged turbo let alone an old dinosaur T3 turbo .
To quantify , the T3 flange/footprint is pretty big for the sort of exhaust gas flow a 1300 four puts out and not that easy to package on a smallish exhaust manifold . Its this very reason that Nissan went to the T25/28 footprint on SR20s and RB26s - they are compact and easily up to the task flange size wise .
On someone elses computer I have a link to I think an Australian starlet site - to a thread about some fella doing a Mitsibushi TD04HL turbo for his Starlet GT . Does EP82 sound familiar ?
Your call but if you can get the factory exhaust manifold from a turbo Starlet this could be a good starting point .
If they used a TD04 and a suitable turbine housing - or mount flange style - I can give you lots of info on TD04's .
People write these turbos of as useless because all the Rex boys throw em away for a TD05 , they don't do their homework to find out about the full range of turbines and compressors available in the TD04 range .
When I find the starlet thread I'll find what that fella used but I'm pretty sure the cartridge was a TD04HL 19T .
Cheers A .
I would have headed in that direction if it weren't for the fact that he actually has the T3 flange setup already, and I have been in a Starlet of the exact same model running a T3 turbo on it with no problem whatsoever. I honestly wouldn't have believed how well it behaved on the street if I hadn't experienced it first hand - i doubt I'd want such a thing to come on any faster as the doughiness down low was enough to stop it from frying the tyres uncontrollably.
I've also been in a Starlet running a WRX TD04 (and for that matter one running a T25) and the difference between the lot isn't half as obvious as you'd expect. For what its worth the car has been upgraded to run a .63a/r turbine housing and a Super60 compressor wheel and is still perfectly streetable, just last weekend it did a 12.4 @ 113mph on 12psi (seriously!!!) - it has some bigger injectors and pump to go in for a retune to find the limit of the turbo and some faster times.
Edited by Lithium
This is the site and thread I was thinking of .
It sounds like he is using a Subie spec (both coolant holes on same side) WRX TD04L 13T/6 with the housings bored out to suit the larger sized "HL" spec turbine and 19T compressor wheel .
http://www.austarletclub.com/forums/index....1&hl=TD04HL
Silly me was not thinking of Toyotas and CT series turbos , std on those sounds like a CT9 .
Hope this helps , cheers A .
Thanks Gang!
Yeah i'm an active member on the austarletclub forum - i did the turbo half cut conversion myself into the later ep91. (rewired the sucker twice - that's fun)
The TD04 off the rexies is a popular upgrade and even the TF035's off the forrester's which have a slightly smaller exhaust housing.
The T3 swap isn't to popular and there is minimal info on the starlie site regarding T3's.
As i got the adapter/ex gate/dump for a steal (no not stolen :huh: - $65) i thought it best to research the possibility of putting a T3 turbo on....
The plan is to keep it driveable, not thrown bucketloads of $$ at it and have fun in it... currently she's churning out a blistering 93kw on my first SAFC tune but with a few little things to tidy up and new actuator i should be able to get it up to abt 110... not bad for the stock CT9 Turbo, stock injectors, FMIC & Log exh mani...
Massive thanks Mr Lith & Discopotato03 - you guys are gangsta!
    • @GTSBoy yeah i know it was not the "great" idea but it is and option...but i think i will stay on no BoV rather then trying to make it work with "half" this and that. But that GReddy FV2 is cool...i like that you can make it like stock if you want (and have/make the custom pipes) For other thanks! it was alot of information. But for the sound...a dont rly "like" both of them...specialy if they are loud...but if i "must" choose i would rather have little whooosh rather than sutututu with no BoV....BUT that is what is i gonna get. So for the all info i gather. In my case:  No BoV is not that bad cuz it is stock...and iam used to put N/clutch right after rpms are around 1000 so it should be ok...just need to avoid "big" drops. But i do not have the engine in the car so i do not really know how "bad" or good it is. But as i had that little test drive it looked ok. The atmo BoV should be worse car would dump to much fuel specialy between the shifts...so without proper tune/ECU i dont want that. BUT with that...car should drive ok with no problems right? (i do like there is less piping wih this solution) 馃檪
    • Usually an RB20 won't stay in closed loop idle anyway. The O2 sensor gets too cold, stops swinging.
    • They aren't, but it depends on what interests you about an R32-R34. If it's the front engine I6 turbo that tunes well with a manual transmission an E92 335i 6MT is so incredibly cheap. You can get a super clean one for 20-25k USD tops. Put an LSD in it, tune it, have fun with it. If it's the general idea of AWD + turbo and a manual transmission the 996 Turbo is absolutely much more expensive, it's less practical but it's also basically a complete track-ready car from the factory. At least the Mezger doesn't have heaps of oil control issues. And in the US the 996 Turbo and R33 GTR are roughly the same price these days. 996 maybe a bit more now that the hype has abated for old Skylines here.
    • these are not the same
    • Best kept secret for seized bolts is crayons... Heat the sucker up with a torch, and push/melt crayon into it. Works a wonder. See if I can go 2 from 2 for you on how to get your bolts out...
