gday guys recently had some probplems with my r32 ...it wil start and idle but idle wil slowly come down to a stall and if i try to rev it it wil hesitate something shocking al i can hear is air poping back through the pod filter .. and it wil rev to 4 grand and then just back fire as if rev limit was at 4grand any help please
check your afm and also youur O2 sensor...sorta had the same prob and i changed afm and it fixed it for a bit and then i scanned my car and it said the O2 sensor was buggerd so i just disconnected it and now it runs a dream..hope this helps.
  • 3 weeks later...
yo man this happened to me, what mods are you running on your car?. what you can do is, first clean afm like said above, then check coil packs for any cracks, then make sure all spark plugs are good, and have got the proper gapping.. If it still doesn’t work and if your car has a decent amount of mods, change the fuel pump..
i had the same problem a week or so back, where my car would hit 3.8k-4.2k and start back firing very loud and the car wouldn’t go, so i put a gtr fuel pump in and it fixed the problem so it could be a fuel pump issue
Good luck man
niran
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
