hey guys im kinda new to this forum any ways i bought a r33 not long ago and i love it but the only thing is its got really ugly lights like they look dirty ive asked about getting new ones but i cant find any one that has got a good pair so i thought ill try on this forum ive seen a couple of other skylines wit hthe same problem so yehh any help on how i can clean them or were i can get new ones
ps:sorry about the long thread :(
https://www.sau.com.au/forums/topic/25646-dirty-head-lights/
If the crap is on the inside you will have to pull them apart, which is a real bitch. And then use sealant to put them back together again afterwards, which is also a real bitch. My sympathies for anyone with clouded lenses from the inside.
Autosol also works pretty good on dirty lenses.
https://www.sau.com.au/forums/topic/25646-dirty-head-lights/#findComment-545397
yeah Meguires plastic polish brings them up a treat (little blue bottle available from Kmart or Supercheap) only thing the effect only lasts for about a week then they are back to their grubby selves :D
but its a quick job so i dont mind doing it every weekend.
https://www.sau.com.au/forums/topic/25646-dirty-head-lights/#findComment-545891
Just Jap in Sydney also have a pretty good plastic cleaner,
"CLEANS DULL PLASTIC HEADLIGHTS (SOARER ETC) $24 A TUBE"
Only prob is as nizmo said, it gets all grubby again and needs cleaning again, i wish it didn't cause one headlight is perfect the other isn't so perfect :D
Kris
https://www.sau.com.au/forums/topic/25646-dirty-head-lights/#findComment-545938
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
