Rpm Stuck On Tacho
shotter
 Share
As usuall i get a problem that is sometimes there and sometimes not.
Sometimes the rpm will rise and fall as normal.
Other times when you turn the key to on (with the engine off) the rpm will jump to 500rmp and stay there. Then when you start the car it will just sit around 3000 or 4000rpm and not move, Even at idle. Then it may very slowly move between 4000 and 3000rpm, then even down to 2000rpm. And then it may just start working as normal.....
Now i have connected my laptop to the ecu while the problem is happening and the rpm is perfectly fine.
HELP PLEASE
HELP PLEASE
Hi there, if the rpm signal is clean from the source or somewhere downstream of the source as displayed on your laptop then perhaps the next area to check is wiring loom after that.
No doubt you have checked all connections, made sure they are clean (as in not corroded). Weird intermittent faults can be due to corrupted primary signal/power/earth paths for the circuit, whatever the item or system is, particularly if it has evolved rather than "happened" after some other work has been carried out. Next thing to check (if it was me) would be for dry joints on combination meter circuit board.
My 2c
Good hunting, GW
The only things that happened before this started was i got the car tuned and the CAS was swapped with another one to try and trouble shoot a problem we were having, Swapping the CAS didn't fix the problem we were having but the other one was left on the car. A few days later i started noticing this problem
Swap a dash cluster with someone, see if it's the problem.
You said;
"Swapping the CAS didn't fix the problem we were having but the other one was left on the car. A few days later i started noticing this problem"
Still got original CAS? Worth a shot I reckon although I have no idea were the source tacho signal comes from, never had to dig it up............yet.
Cheers GW
 Share
    • I know there's been no posts for 3 years, but figured it wasn't worth starting a new thread for my question. The nice Japanese lady in my V36 occasionally/randomly speaks to me whilst I'm driving.  Of course my Japanese is very rusty, I'm guessing it's to do with the Nav system? Anyone have knowledge on this?
    • there are probably many ways to do it for my bosch motorsport abs we used a r33 gtst abs front knuckle and modified the rear knuckle to allow sensor to sit and read understand time, effort and $$ but reading from anywhere else  you get diff chatter etc where you lose 30% ish in signal clarity compared to the above
    • Little more work!  Did some body work on the rear wheel arches and since the paint was a cheap spray job before figured I’d do something to tide me over until I wrap the car.    Colour might not be everyone’s choice but I like it and it’s only temporary, just hate having primer from the wheel arches standing out.    Keeping an eye out for a decent set of wheels to throw on now. Wheels and tires on the car are junk
    • Its likely to be 70% road 30% track usage, track usage will increase if anything. Decided not to fit it as I cant be arsed changing the bushes on my LCAs again 🤣 I did get the below back from GKTech though so they should work together     The anti-squat kit and roll center adjusters work independently since they change the rear lower control arm's angle in different ways. The anti-squat kit adjusts the angle from front to back, which impacts anti-squat values. Roll center adjusters change the angle side to side, mainly to correct geometry on cars that are significantly lowered. They might affect each other a tiny bit, but overall, you can think of them as separate.
    • What are you doing with the car? street car or race car? People get hung up on the squat of the s/r chassis rears. There is positives to the squat if a car is setup and driven correctly for it (correct ride height, spring rate, alignment, damper valving). Generally just lengthen the rear traction arm by 5-10mm and that will help the squat and bump steer too. You are also correct with the roll centre too. This too also needs to be adjustable if you start messing with suspension geometry.   Having done quiet a bit of testing on race cars this year in regards to rear squat, I've seen some big positives from it in regards to drive off corners and traction.
