  • Replies 51
Posted Images
Here are the pics taken this morning, a bit of (amateur) pp work done in photoshop. Couldn't help myself :unsure:
It's actually not as low as i thought, it sticks out a bit more then the Dayz that's why it looks lower then it is. Drove it around town/bp/maccas this morning and didn't scrape anything. Basically as long as i remember to slow right down and approach any dip at a slight angle, it's all sweet. Very happy with Norwood Panel Works jobbie too, can't tell the paint difference can you!
[atta
chment=216661:4.jpg][attachment
=216664:7.jpg]
looks good buddy. only thing i dont like about it, that i just picked up from your pics.
then opening's and vents in the bar, it looks like it was drawn up by a 5yr old kid. so straight and square.... i'll put on of your pics as my desktop backround so i have to get used to it lol
haha! i see what you mean. I like my things straight and square like that :unsure: so it suits me :unsure:
Tell you what though, i'm glad i got them to paint the mesh inserts matt black before putting them on. They came in a silver that would have just looked strange.
Edited by webng
haha! i see what you mean. I like my things straight and square like that :blush: so it suits me :)
what was the front bar fitted and painted worth. if you don't mind me asking?
sorry if you already mentioned it didn't find it. did it pretty much bolt on and line up?
It was an insurance jobbie so i don't know final cost. Bar delivered from QLD was about $600. Original Dayz bar was going to cost around $3k from japland.
according to the panel guys it was a bit of a pain to mount but all in all a fairly decent piece of fiberglass. Needed all the connections drilled and bolts put on which delayed things a bit.
oh yeah their bonnets for stagea ..
Vented $770
TJ, are you saying that Blits are doing vented bonnets for the Stagea? I'd love one (eventually) on my s1 if I can get one. And if Blits are doing them, I'd say it's safe to assume they'd be ADR-approved like most of their stuff, right?
*checks website*
*checks website*
ADR Aproved (Australian Design Rules)
NSW RTA Aprroved
very diffrent rules
Bonnetts are adr approved and come with individual no. stamped and papers.
Front bar looks good! sell me your old one!
I've agreed with the Mrs we'll trial this one for a bit because it's still lower then she's comfortable with. Sorry!
pretty sure it would be ADR, because in HPI mag they were giving away a r34 gtt vented hood ADR approved.
got the pic in my inbox somewere, got a pretty wide vent, facing the windsheild. e-mail them see what they can do, i got a nice deal on the whole front setup, just waiting for credit card to rock up then BAM!
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
