hey guys i got a 32 skyline its black with a glitter through it pretty gay but looks ok... was painted about 3 years ago..
it is sittin on 18 inche white wheels with new tread al round..
been lowered with coil overs in rear and not to sure about front...
lookin more for a swap to see what i can get for this thing or just throw us an offer it had 10 months rego aswell with 165.00kms always serviced with brand new clutch drive perfect...
pretty standard interior just got head deck 6's in door and 6by 9's in rear runnin off amp and a 12inch sub in boot..
goes well for non turbo and perfect for p platers..
just pm on here or call me my number is 0435035067
thanks
p.s lookin more for swaps but throw me some offers
https://www.sau.com.au/forums/topic/256471-eoi-p-platers-dreammmm-32-na/
i have 96 vs commo stock auto, subs head unit, pod filter 18X,XXX
would make a cash adjustment your way
new rego
adelaide
just throwing it out there not expecting much
trying to find a na 32
where bouts in nsw you at?
  • 3 weeks later...
  • 1 month later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
