Hi guys, this has been bugging me for a while. In my R34 GTR, I have a switch located down and right from the steering wheel, underneath the driver's side air-con vent (see pic). The red light flashes when my alarm activates.
I have tried flicking the switch, without any noticeable difference, whether driving or not. I have asked this same question in the Vic forums, and no-one knows what it is, so I thought I'd get some interstate opinions. I really didn't know which forum to post this in, so I just picked the most popular one. Apologies if it's in the wrong place - mods please move if this is the case.
Things it is NOT (I have personally tested these out):
- Kill switch
- 2WD/AWD switch
- Low/hi turbo boost
- Neon switch (I have never had those eyesores)
- Airbag suspension
- Anything alarm/immobiliser related
- Fuel pump switch (stock fuel pump)
- Cheat switch (flicks on stop lights to fake out chasers on the track)
Thanks guys.
No one is going to answer your question because it's an aftermarket switch and could literally have 100 uses, or not be hooked up at all.
Get your head underneath the dash and see if there is wires leading to the switch, if so, what from? This will narrow it down.
Or take it to an auto electrician and tell them to find out.
haha I had a switch just like this in my old SS, the urge to press it got the better of me one day, and I managed to turn the alarm off, and neither I nor a mechanic could work out how to turn it on again. Lucky that in your case it didn't appear to do anything!
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
    • Ok...its taking me long enough to finally do this.  Feck financial security...heart disease will get me soon enough anyway So welcome to the garage..."Clem" Belsil80 has been running a 370Z in Super TT series. So after entering with him in last years Winton 300 i figured I  need my own car. Seems SAU Vic race cars need to be yellow....{tick} Reckon with enough motor i will be able to make up for the lack of talent and stay ahead of the 370Z... but the LS powered S13 and E36s are a ways up the road Aim is to have a car that doesnt stop or turn but has a bit of shed built motor with jam...maybe some cream  First step is getting this ex drift car log booked I am keeping faithful silver car. As the road-club car gets upgrades the race car wil get the sloppy seconds
