Hey Everyone,
I'm in the 'slow' process of collecting parts to get my RB26/30 build underway - End result will be to achieve around 300rwkw with a lot of response (rev limited to around 7200-7500)
Items already purchased:
RB26 Head - complete with covers
RB26 std inlet plenum
RB26 std 6 throttles
GT3076r - 0.82 external gate
TIAL 38mm external gate (14psi spring)
6 Boost manifold
Now i'm looking at buying these bits as i go - just hoping people can speak from experience and point me in the right direction for what is good value, where to get it from for the best price - The build isn't supposed to be all out, just would like to keep it reliable
Items to be purchased:
RB30 block (series 2 - as means oil drains already in block?)
Forged pistons & rings
Rods
Oil pump
Metal Head gasket
Arp rod bolt kit
ARP main stud kit
ARP head stud kit
ACL Bearings
Water pump
Harmonic balancer (std?)
Modified sump – rb30
Custom oil drain & oil restrictors (or is this mainly to suit RB25?)
Crank collar
All other machining etc to suit - completed by Nisspeed here in SA.
Here are a couple of pics of parts obtained already,
cheers
-Matt
https://www.sau.com.au/forums/topic/256483-my-2630-build/
for your power goals i think the engine is abit overkill, forgies etc are not really needed, just freshen up the stock block and it should run 300kw pretty easily, and head studs etc not needed either.
The common belt everyone seems to use is the Dayco 94407, its about $35 or so, i reckon spending $100+ on other belts isnt needed.
If you plan on upgrading turbo later than think about forgies etc but with the 3076r i personally wouldnt bother. my motor i recently did i wish i went straight for the gt3582, the 3076 just doesnt have that throw ya back in the seat feel i was hoping for.
just my 2c worth ;)
Edited by unique1
https://www.sau.com.au/forums/topic/256483-my-2630-build/#findComment-4419218
If he plans to use the car like his avatar then he needs a very strong engine. If you have the money no need to skimp on reliability.
I love the gt3076r on my rb30det, it's freaken awesome, power and torque throughout the whole rev range!
My only concern about your setup is the 38mm ext gate. You my get boost creep, I would have gone for at least a 45mm gate.
https://www.sau.com.au/forums/topic/256483-my-2630-build/#findComment-4419420
Hey cheers guys - building it to be as 'reliable' as possible - mainly for drift, but also something i can just have fun in. Wanting to do some grip/hillclimb/drag aswell.
Initially i went for the turbosmart 38mm, but I spoke with Simon at morpowa (has a 2jz with 6boost manifold, 38mm tial, gt3582 no boost issues) and he also spoke with Kyle (i think thats his name) from 6boost and came to the conclusion that if i change to the TIAL 38mm i should have no probs.
I know you always hunger for more, but this is the route i'm going atm.
Here's a pic of the car before my old TOMEI 2.4 was removed and the car was stripped getting ready for CAMS cage.
...So who can tell me where to buy stuff :huh:
https://www.sau.com.au/forums/topic/256483-my-2630-build/#findComment-4420430
Hey Everyone,
6 Boost manifold
Rods
Oil pump
Metal Head gasket
Arp rod bolt kit
ARP main stud kit
ARP head stud kit
ACL Bearings
Water pump
Crank collar
cheers
-Matt
RB30 block - Every single rb30 i've personally seen (which is about 15 to date) has had the bungs for all the oil/water lines
Forged pistons & rings - Mahle pistons from USA or get the rod & cp piston combo from spoolimports, if u use the cp pistons get a set of acl oil rings to suit
Rods - Spool rods
Oil pump - i'd personally put a tomei on it, or better yet an external. ur going to be ringing its neck, lets not hide that fact lol
Metal Head gasket - acl gasket kit will surfice
Arp rod bolt kit - comes with the spool rods
ARP main stud kit - required for ur application
ARP head stud kit - required for ur applicaton (u'd be after RB25 headstuds)
ACL Bearings - yep their good
Water pump - genuine nissan
Harmonic balancer (std?) - atleast a ross balancer, ati if ur going to run an external oil pump
Modified sump - something with extra capactiy, gates & baffling
Custom oil drain & oil restrictors (or is this mainly to suit RB25?) - -10 drain from back of head, oil restrictors
Crank collar - proengines do them
id also put some poncams and springs in it with adjustable gears
hope that helps
https://www.sau.com.au/forums/topic/256483-my-2630-build/#findComment-4420753
Thanks for your help :)
That spool site is good - i've flicked an email off to him so thanks for that.
Why is it RB25 head studs are required? same as 26?
With the custom oil drain is it like this?
http://www.spoolimports.com/content/SPOOLR...OilDrainKit.asp
are these the oil restrictors? http://www.lewisengines.com.au/prod79.htm
how do they work?
Also looking into Moroso oil accumulator
Edited by huddy
https://www.sau.com.au/forums/topic/256483-my-2630-build/#findComment-4421024
the rb25 head studs will screw into the 30 block but the 26 studs are bigger and would need drilling and tapping the new thread. just make sure u have both the head guides before u fit the head gasket and head so the head wont move around.
https://www.sau.com.au/forums/topic/256483-my-2630-build/#findComment-4421049
Thanks for your help :banana:
how do they work?
heres a bit on the oil restrictors,
https://www.sau.com.au/forums/topic/256483-my-2630-build/#findComment-4421723
ah, mr huddy, i have read a few of your posts in the cefiro forum. going 26/30 aye? i ran a bottom end bearing in my 26 cefiro and have also decided to go 26/30, i purchaced a series 3 siloette rb30, it has all of the oil lines in the block, i think there was one for sale on boost cruiser for $150. just having fun extending the down pipes off the twin turbos at the moment, not so easy doing it in the shed. good luck with the build. if you are running a 26 head do you still need to run the oil restrictors, isnt one of the oil galleries blocked off? i have noticed the 26 block has one of the oil galleries blocked off compared to the 30 do you need to weld up the 30s oil gallery? is running baffels in the sump necessary for a 30? any information will be greatly appreciated. sorry for crashing your thread huddy
Edited by brada31ke70
https://www.sau.com.au/forums/topic/256483-my-2630-build/#findComment-4424804
Not all RB30's had oil feed and return bungs in the block.
Very early VL's had the series 1 block which has no ports for oil/water lines, to be honest, I have only ever seen one!
Pretty much all R31's have the series 2 block.
I am doing the same engine for my wifes car. I have the rb30 bottom end with a 26 head. My biggest issue is to go twin high mount turbos as my head came with a brand new twin high mount manifold, or a highmount single.
https://www.sau.com.au/forums/topic/256483-my-2630-build/#findComment-4431586
Just buy a cheap RB20 and throw a 26 crank and rods at it ...err oh :)
I think you're over due for another drive of my car Troy, just to jog the memory banks :(. It's a little different than when you drove it during the "run-in tune", that's pretty much my low boost now; high boost unleashes an angrier beast :wave:.
Still have some more "tuning experiments" that i want to try, to see if she has more in it, should be sorted in a few weeks.
ie: Apexi exhaust, adjustment of inlet and exhaust cam gears, etc.
https://www.sau.com.au/forums/topic/256483-my-2630-build/#findComment-4432815
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
