Man i got a GTS4 and i'm gettin a 600x300x80 that thing is tiny man go for something a smidge bigger i mean i only got Zorst, Dual Boost controler and thats it.
In this case bigger is usually better but not too big don't want too much of a pressure drop etc.
In a word - yes
It would probably be fine even if you intend going a larger turbo as well, something like a HKS2530.
the best sized cooler is one that is optimum for your hp goals - too big and you will get extra lag and a more sluggish throttle response.
going by the aftermarket coolers I have seen (not too many, so please dont take my words for gospel) a 'good' cooler of the dimensions you quote should be good for over 400bhp.
to quote http://www.horsepowerinabox.com/make_model...skyline_r33.asp
Note this isnt a Jap brand name cooler that they are talking about, but a local product. I have no reason to believe that a japanese product is going to be inferior:)
This intercooler uses an 18”x12” high by 3.5” thick bar and plate intercooler core, smooth aluminium tanks with 60mm inlet/outlet and centre mounting points make for quick easy fitment with minimal front bar trimming. The core itself is rated at optimum 580 horsepower with 1.5 PSI pressure drop at that level.  We have made up to 630 horsepower through these cores but with nearly 2.25 PSI pressure drop.  This cooler was featured in a Zoom magazine technical article where it proved to reduce air intake temps by nearly 25 degrees over the standard intercooler during testing where the car was run at 11 PSI for 15 seconds at 5000 RPM.  The standard intercooler had a pressure drop of up to 8 PSI at 7000RPM whereas this one had a mere 1 PSI drop.
A bit of that is probably sales pitch, but I dont think it would be far enough away from the truth that it wouldnt be reasonable to expect good performance at up to 400 or 450bhp
my 0.02 anyways
Gradenko: Not too much since I'm just looking to learn how to work on the rb motors. I've already put a turbo timer and a hks exhaust on it. Looking for an intercooler and boost controller (probably greddy profec B). Changing the plugs soon but so many different opinions and I don't know what's in there right now. I checked the NGK catalog and it says 5 but then some people say 6. I don't know if to go platinum or iridium, heat range 5 or 6? I've searched many threads but still indecisive.
Madgt4: Wow, that does sound pretty large? Are you going to have too much pressure loss in that i/c? I guess that depends how efficient it is.
Steve: No, I'm not upgrading any turbos or anything. I'll probably be purchasing hks2530's from what I have read later for the R33gtr or R34gtr.
Thanks for all the advice, I'm just looking to upgrade a little and learn on this car before I purchase my R33gtr or R34gtr next year.
Anymore advice would be great. And yes, I haven't been posting much because I've been searching and reading through everything first. :(
That cooler will be just fine dude.
Your standard cooler will be fine for around 12 psi through the standard turbo.
Put it this way.
The standard size that MOST companies make there intercoolers is 600 x 300 x 70.
A standard GTR cooler is something like 600 x 270 x 70 (I think).
If TRUST has decided to make a cooler that is slightly smaller for a car that is more lightly tuned, I would buy it.
Actually, I would buy anything TRUST makes if I could..
send a PM to "rev210" asking about your intercooler....
He has run a 12 second pass in his R33 GTST with the standard cooler which is not that better than the R32's..
He'll set you straight.
I was under the impression that he never got his 12, just low 13s??
BOOSTD managed a 12 with stock turbo, but he had a cooler.
my mistake.
still.
decent number with a standard intercooler.
My point was that rev210 is one of the guys int he thinking that the larger the intercooler is not really a better thing.
It has to be matched to your turbo and so on.
So this particular intercooler 410 x 260 x 70 made by a company like TRUST will be mroe than enough for a R32 GTS4 with a cat back exhaust as the only mod.
Actually, that intercooler would be more than enough for anything the standard turbo will be able to handle.
Thanks guys. I actually forget to say that it has a hks highflow filter but it was on there when I purchased it, not that it matters.
As I said, I just plan on putting a greddy profec b and the i/c before I get my gtr.
By the way, any suggestions on my plug situation. I'm fixing to order them. And yes, I have searched but still with so many opinions. What do you guys run on your gts'?
Thanks. I was checking those out and noticed that the BCPR6ES plugs were gapped at 0.08mm and the BCPR6ES-11 were gapped at 1.1mm (0.044"). I guess I'll be ordering a box today since I can get those for only about $3 plus shipping of course. I've checked local auto shops and they want $12-15 per plug.
Seriously, I'll be ordering over the internet. So GTST, you went with "7's" since you went colder? I know NGK does it differently than others and the cold-hot is opposite. Higher number, colder the plug from NGK. I hate that when I'm ordering for my gsr because I normally get 2 steps colder.
my mistake.
still.
Also you forget revs car was a freak and hes been the only one able to get such a low time with stock stuff!!
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
    • I definitely agree with you there - I never click on content for cars I would never ever be able to get or compete with/against/be seen next to. Seeing a MX5 compete with a FD RX7 will make people upset though, for sure. Even in 2.5L Turbo form which is pretty grass roots. (or at least as grass roots as classic cars can be) Yes we're all classic car owners now.
