good choice for you I think
use the rb26 ecu and loom afms etc .
you gear box will bolt up hicas and abs are separate to the motor..
you will also need a different sump for the rb 26 as that one has a diff in it your rb 25 sump could work but might need a few mods
meggala
u will need to modify and splice the 2 looms together. as for the rb25 keep it aside , as u will need bit and pieces of it to make your rb26 works. also the power steering pumps need to be modify as the rb26 is a dual lines unit and a rb25 is a single feed item, hopes that help abit. but do it, it brings smiles on your faces every drive.
Four more questions :(:
1. what is sump
2. what does loom mean?
3. Will GTR ceramic clutch fit my (rb25) gear box?
4. I heard that 280 hp is a law limit in Japan. But the real potential of rb26 engine is much higher, so how do i use the potential - just get a reprogrammed ECU?
about the power steering pump - i was planning to fit my pump to that rb26 engine, i guess it will work fine?
rb26dett sump has the front diff moulded to it so u cant use in your car but u r rb25 sump should fit on the rb 26 block thats what meggala was all about other option would be to modify the rb26 sump cut the diff off and a bit of welding .
yes you will be able to you will just need to have some one doit who can trace the wires back . the speedo runs off a cable to the gear box you will need to find the source for the tacho. one trick is to keep you alternator and starter wiring from the rb 25 .
I think your water temp should be ok as well oil pressure should be the same or very similar.
I fitted an sr 20 into my r32 most things in my dash do work only the tacho isnt working but we will sort that
meggala
The tach is simple, just find the wire for the tach on the cluster, should be yellow/red, then find the wire on the ECU pin out, and splice a wire from the ECU tach signal wire to the wire in the back of the cluster. Thats how I got the tach to work in my RB20 240sx, but I had to put the R32 tach into my 240sx cluster, meggala, you may need a different tach, I know the SR20 has a different signal than the RB20 tach signal has. It reads 2x as high with the tach meant for my KA.
Originally posted by Vovan
Thanks a lot! i will be doing all this stuff myself :) will spend whole winter to prepare my car for the next summer season. i guess you don't have snow in winters? :)
we dont have snow... just rain, that makes for good, WIDE, drifto at the saving of tyres!
But yeah, if you can do it yourself good luck, post up pics too.
I love seeing 26's.
There is a 26 going into and R31 here in melb ATM. It's been done before but it's still cool!
    • Hi guys, Sorry to butt in and take it slightly off course, although still on the VCAM subject.  I had VCAM put into my Tomei 2.8 bottom end and I struggle to take off because the engine has very little torque caused by VERY low dynamic compression at 60psi. But once off the mark and especially on boost, the engine rev happily all the way to 8000rpm and makes 630hp at 20psi of boost on E85 at the rear hubs. Has anyone had any similar experience or any suggestions on what might cause this low compression at low rpm? I am in the process of converting it into a 8hp transmission and with this low torque, the engine would not even stay running until the throttle is opened to more than 30% and then I loose all vacuum.
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
