Hi,
I have a R32 GTR that stopped boosting today. Everything seems to be running fine, engine is smooth but no power due to no boost.
Boost gauge doesn't go past 0, there's no smoke etc, and I cant hear the turbos spool up.
Could anyone please advise what the problem might be. If there is a boost leak shouldn't I still be able to hear the turbo spool up? how do I find a boost leak.
Has my turbos crapped it?
I have N1 turbos to bolt up but don't want to do it till I get a few more parts for a major upgrade.
welcome all advice, as I'm desperate to get the car running properly again.
GTR with no boost = ;)
https://www.sau.com.au/forums/topic/256539-gtr-not-boosting-need-help/
Hi,
GTR with no boost = :huh:
If the gauge goes from - up to zero, quite possibly your turbos are still working but not making positive pressure indicating a intercooler hose may have popped off, but I cannot explain why you can no longer hear the spooling if that were the case?
were you driving along giving it a hard time when suddenly things went 'pop' and thereafter no boost? or one day you started the car and no boost?
Edited by R33GTRKid
Yep my boost gauge still indicates that it's going from negative to 0 boost but not past that.
I did hear a weird noise the day before but I thought that I had run over something and it was close to home so didnt notice the difference in power. When i started it the next day and took it for a drive (uphill) this is when I noticed the lack of power.
I never drive the car really hard, and was looking to see if any vacum or boost hoses had popped off but cant see past the manifolds.
If it is a intercooler hose poping off wouldn't the car idle really badly? cause mine is idleing and running fine.
Could a wastegate problem cause this as well?
Had a conversation with Bel Garage and Advan today and they both seem to think its the ceramic wheels shattering.
How much should I be looking at in labour to get turbo's changed over? Advan want $1000 Bel Garage want $660 is this about right and can anyone recommend these guys workmanship?
If your ceramic wheels had gone, the boost gauge should be reading 0 or there abouts all the time.
When you accelerate & put the car under load where the turbos would normally spool up, does it seem to miss or sound different?? When a cooler hose popped off on my own car the other day, the idle was fairly normal, but as soon as i accelerated it was popping & farting & just generally not going at all. Do you have a factory ecu in yours?? Remember the factory ecu's have the safety feature where the car wont build any positive boost while in neutral or the clutch is in. Could it be that 1 of the sensors used to detect either of these conditions is playing up??
If the turbos were gone, you would expect smoke &/or a 0 reading on the gauge just about all the time. Personally i dont think turbos, but im not a mechanic so diagnose it & fix it however suits you best.
Good luck with it.
thanks for the reply guys.
Yep still running standard ecu at the moment, and no miss fire or popping when under load.
I guess this will speed up the process of fitting the new turbos. Just bought a set of dumps and apexi front pipes but still looking for manifolds so that I can install all at once.
Will it still be ok to drive to the work shop or am I tempting fate and could cause some bits to go through the engine?
manifolds net zero gain...a waste of $$...i charge $880 so the quotes seem good.
Really? I thought the standard R32 manifolds were quite restrictive?
Please explain, as I wont bother if what your saying is correct
STD GTR manifolds are a great piece of kit...well designed and keep the heat in the gas path, hence increase gas velocity and flow. A thin walled stainless manifold allows the heat to escape and looses this advantage of super-heated high velocity hit on the turbines.
Its well proven with back to back testing that stainless manifolds do SFA when using low-mounts. A set of prepped stockers will outperform them everytime...in both performance, durability and cost.
Edited by DiRTgarage
+1 port match your standard manifolds, the restriction at the turbo flange is quite large, check the gasket marks. While not doing anything for power as every one says, it will improve your spool up response. Always a bonus on the GTR. Funny how both your turbos have gone at the exact same time?
cmoney- engine will still read vacuum if the turbos are shot. Just like an NA car.
If you can get 0 (atmospheric pressure) on your boost gauge, then the turbines are spoolling up in the exhaust gas stream. If BOTH ex wheels had shattered, you would be running a N/A setup, and N/A engines cannot get to atmospheric pressure (they always run in vacuum).
Somewhere in your intake system, a connection is opening up as the system hits boost, dumping the boost pressure.
It's not necessary for both turbos to blow simultaneously to make no boost.
Breaking one turbo on a parallel arrangement like the stock GTR means that one compressor no longer works;
so the air pushed by the other compressor can go:
* through the motor; or
* back out the compressor of the broken turbo
It takes the path of least resistance, so for the most part it does the latter, making your car basically N/A.
If you fully block the intake of the broken turbo properly you _should_ make boost again - exactly what boost I wouldn't know,
I never tried when one of my twins went - but you'd then have a single turbo trying to do twice as much work as it should be doing...
Regards,
Saliya
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
