Hi Guys,
I've found plenty of info in regards to putting an rb25 into r32 using the 25 loom & Ecu. Also there's plenty of info on using a rb20 ecu on a 25 loom but cant seem find info on running an rb25 using a 20 loom+ecu.
The reason i ask is because i'm doing a conversion and already have a rb20 power fc wired in with a q45 afm and big injectors and was wanting to know why i cant just swap everything (all sensors + CAS) over onto the rb25 and just tune it to suit. I'm not fussed with vct as i'm going solid lifters.
Also i have a greddy plenum with the rb25 will the 32 IAC fit? Is there anything obvious i'm missing out on by not using the 25 loom?
https://www.sau.com.au/forums/topic/256546-rb20-loom-ecu-to-run-rb25/
  • 6 months later...
I'm considering an RB25DET as a replacment for my rb20det (that is destroyed). I too went through all the threads I could find on 25 swap into a 32. I didn't seem to find too much info on running the 25 using a 32 loom and computer. I'm not too fussed about the VCT as I can play with that later.
Any info would be great.
Cheers
Justin
IMO is easier to just get a RB25 loom and make it fit your R32, you can still use your RB20 power fc too
Most defiantly but that wasn't what he asked was it Simon :D
I was under the impression that you couldn't use a RB20 pfc for RB25 unless it was also modified accordingly???
lol i read what he asked and i saw that you gave the correct answer, so i just chipped in my opinion :D
If you want to make a RB20 loom fit a 25, the S1 motor is the one to do it with, injector plugs and knock sensor loom need to be changed along with quite a few other things.
a RB20 PFC will run a RB25 no worries, as will a RB20 ecu. doesnt matter if its series 1 or 2. It just wont control VCT.
HAHA i know i was only throwing the line out mate :D
I didn't think you could use a 20 ecu on the S2 25 because of the ignitor set up???
well guess what mate... you can :D
My neighbor bought a S2 R33 which i did all the work on, fitted fmic, exhaust and a host of other basic upgrades. I chucked the R32 ECU out of my 32 drift car which ran a s1 RB25 into this S2 R33 and it ran straight away. So i got him another 32 ecu, then got it chipped and tuned for him and it made 215 rwkw with basic upgrades and stock turbo. Car has never run better.
Basically the way it works is that the ignitors are independent to the ECU, the ECU provides the coilpack a trigger signal and the ignitor on top of it gets that signal and fires the pack.
Why cant I use the rb20 ignitor module, coil packs on the 25?
My plan was to strip EVERYTHING off the 25 and fitt-retrofitt all the 20 ignition set up, sensors-etc. Any reason this wont work?
I have top feed injectors and rail for it, so injector plugs wont change. A Z32 so the afm plug will change anyway. Slip the 20 CAS inplace of the 25 CAS, swap oxy sensors, bolt the 20 knock sensors in place of the 25 sensors, swap out all the temp and pressure sensors from the 20 into the 25, use the 20 coil packs and ignitor module, and so on.
Then use an rpm window switch for the VCT and play with the idle controll.
Use the 20 ac comp and wiring, 20 PS pump, 20 ALT and wiring.
What don't I see... What am I missing???
Cheers
Justin
Edited by XRATED
Cheers
Justin
do that mate u won't have a drama, all the rb20 sensors and stuff on the the rb25. only no vct!!
done it a ton of times, just make sure u use the right impentence injectors or resistor pack
Sweeeeet!
Thanks for the input.
Cheers
Justin
  • 3 months later...
Hi Guys have pretty much got it all workinghowever idle is not great, and once it warms up the idle hunts like mad. does this sound like i don't have the iac working correct?
also what fit s on the purple connector on the iac fromthe rb20 loom? i've only got the solenoid hooked up and i've blocked off the larger diameter pipe and run the smaller diameter pipe after the throttle body.
Also on a side note the solenoid on the iac is an rb30 one as the motor i got didn't have a solenoid on the iac. i know it's a long shot but it looked to actuate the same way and bolted straight up however the 2 pin plug off it doesn't correspond to the rb20 loom, it has a green and white wire. would anyone hazard a guess as to what colour would be power or ground, and can hooking them up the wrong way round stuff something up on the ecu ?
Edited by 4g6beat
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
