Hi Guys,
I've found plenty of info in regards to putting an rb25 into r32 using the 25 loom & Ecu. Also there's plenty of info on using a rb20 ecu on a 25 loom but cant seem find info on running an rb25 using a 20 loom+ecu.
The reason i ask is because i'm doing a conversion and already have a rb20 power fc wired in with a q45 afm and big injectors and was wanting to know why i cant just swap everything (all sensors + CAS) over onto the rb25 and just tune it to suit. I'm not fussed with vct as i'm going solid lifters.
Also i have a greddy plenum with the rb25 will the 32 IAC fit? Is there anything obvious i'm missing out on by not using the 25 loom?
https://www.sau.com.au/forums/topic/256546-rb20-loom-ecu-to-run-rb25/
  • 6 months later...
I'm considering an RB25DET as a replacment for my rb20det (that is destroyed). I too went through all the threads I could find on 25 swap into a 32. I didn't seem to find too much info on running the 25 using a 32 loom and computer. I'm not too fussed about the VCT as I can play with that later.
Any info would be great.
Cheers
Justin
IMO is easier to just get a RB25 loom and make it fit your R32, you can still use your RB20 power fc too
Most defiantly but that wasn't what he asked was it Simon :D
I was under the impression that you couldn't use a RB20 pfc for RB25 unless it was also modified accordingly???
lol i read what he asked and i saw that you gave the correct answer, so i just chipped in my opinion :D
If you want to make a RB20 loom fit a 25, the S1 motor is the one to do it with, injector plugs and knock sensor loom need to be changed along with quite a few other things.
a RB20 PFC will run a RB25 no worries, as will a RB20 ecu. doesnt matter if its series 1 or 2. It just wont control VCT.
HAHA i know i was only throwing the line out mate :D
I didn't think you could use a 20 ecu on the S2 25 because of the ignitor set up???
well guess what mate... you can :D
My neighbor bought a S2 R33 which i did all the work on, fitted fmic, exhaust and a host of other basic upgrades. I chucked the R32 ECU out of my 32 drift car which ran a s1 RB25 into this S2 R33 and it ran straight away. So i got him another 32 ecu, then got it chipped and tuned for him and it made 215 rwkw with basic upgrades and stock turbo. Car has never run better.
Basically the way it works is that the ignitors are independent to the ECU, the ECU provides the coilpack a trigger signal and the ignitor on top of it gets that signal and fires the pack.
Why cant I use the rb20 ignitor module, coil packs on the 25?
My plan was to strip EVERYTHING off the 25 and fitt-retrofitt all the 20 ignition set up, sensors-etc. Any reason this wont work?
I have top feed injectors and rail for it, so injector plugs wont change. A Z32 so the afm plug will change anyway. Slip the 20 CAS inplace of the 25 CAS, swap oxy sensors, bolt the 20 knock sensors in place of the 25 sensors, swap out all the temp and pressure sensors from the 20 into the 25, use the 20 coil packs and ignitor module, and so on.
Then use an rpm window switch for the VCT and play with the idle controll.
Use the 20 ac comp and wiring, 20 PS pump, 20 ALT and wiring.
What don't I see... What am I missing???
Cheers
Justin
Edited by XRATED
Cheers
Justin
do that mate u won't have a drama, all the rb20 sensors and stuff on the the rb25. only no vct!!
done it a ton of times, just make sure u use the right impentence injectors or resistor pack
Sweeeeet!
Thanks for the input.
Cheers
Justin
  • 3 months later...
Hi Guys have pretty much got it all workinghowever idle is not great, and once it warms up the idle hunts like mad. does this sound like i don't have the iac working correct?
also what fit s on the purple connector on the iac fromthe rb20 loom? i've only got the solenoid hooked up and i've blocked off the larger diameter pipe and run the smaller diameter pipe after the throttle body.
Also on a side note the solenoid on the iac is an rb30 one as the motor i got didn't have a solenoid on the iac. i know it's a long shot but it looked to actuate the same way and bolted straight up however the 2 pin plug off it doesn't correspond to the rb20 loom, it has a green and white wire. would anyone hazard a guess as to what colour would be power or ground, and can hooking them up the wrong way round stuff something up on the ecu ?
Edited by 4g6beat
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
