I changed my diff oil using Castrol Synthetic LSD oil (got mine at supercheap) you need 2 litres (takes about 1.6) at $30 odd per litre.
Diff is quiter and car slides more predictably well worth the effort. Fill and drain Plugs came out OK, you will need a oil gun to pump in fluid.
https://www.sau.com.au/forums/topic/25656-r33-diff-fluid/#findComment-545173
duncan, iv'e the old unlimited diff problem as well, actually should make it an unpredictable unlimited 'ish' slip diff :D
what kind of info have you got on diff replacements? only thing ive seen was the upgraded one from UAS, but at $1200 exchange it looks a little too expensive at this point in time!!
https://www.sau.com.au/forums/topic/25656-r33-diff-fluid/#findComment-546201
I've found myself a second hard, v tight diff for $500.
Unfortunately its from a non-abs car, apparently they just unbolt the centre and wack it into my car.
If you don't mind a tight diff, call importers and wreckers, and ask them if they have a diff that a customer hated and made them change back to stock :D
https://www.sau.com.au/forums/topic/25656-r33-diff-fluid/#findComment-546242
true, good point!! will look into it when i get some dosh, will make a bit of difference on the track, way to much spin out of the corner!!
would there be a difference in the abs and non abs diff's?? mines non abs, do you know what kind of difference that would make on the track, mostly is if you actually locked up, or do they brake better in general?
https://www.sau.com.au/forums/topic/25656-r33-diff-fluid/#findComment-546276
The difference between ABS and non ABS equipped cars is the sensors on the housing for the rear driveshafts (I assume Skylines have 4 channel ABS?) that measures wheel speed, or lack of in the case of it being locked.
So if you dont have ABS then no point getting an ABS diff as it wont equip your car with ABS without all its sundry items.
My diff is noisy as hell, oil gets changed regularly with Mobil, but makes no difference to noise.
Any oils out there that are renowned for shutting things up?
https://www.sau.com.au/forums/topic/25656-r33-diff-fluid/#findComment-546317
found out little about my new diff today, its a full 1 way race item :D
I'm just getting the centre swapped into my diff, it came of a skyline with 4 channel ABS (sensors on the half shafts) whereas mine is 3 channel with sensor on the driveshaft
https://www.sau.com.au/forums/topic/25656-r33-diff-fluid/#findComment-546656
    • Hey, yeah I really like the color. Only paint I'd rather have is KN6, but those are expensive. Right now I'm trying to get the car to the point where I can get it tuned to 370hp so the whole setup can be driven legally, and pass the next inspection that is already due anyway. Beyond that lots of rust fixing I'm afraid, winter project is most likely going to be a front end teardown and fixing the strut tower rust. I know these can be driven daily but I don't think I will do so anytime soon. Will post a build thread soon with a list of issues and futute plans.   Cheers
    • Wanted to reply to this topic. I'm in the somewhat same boat with our Stagea. I'm trying to install a different rear diff. The Stagea/Skyline uses mounts on top of the rear diff for the ATTESA pump. Any way you can relocate the pump? I did find this kit https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • So here's the deal, my wife picked up an S2 AWD Stagea. Super cool, clean car. Looks like the owner in Japan went track spec as it's got some heavy modifications including Exedy twin disk, tension rods, coilovers, GTR brakes, oil cooler & a Nismo 2 way rear diff. Now, cool mods for sure. But, she is just using this as a casual daily driver. The 2 way rear is AGGRESSIVE. It also has solid subframe bushings & poly diff bushings. So that doesn't help either. So far I've tried changing the diff fluid to the correct fluid. Even tried a little friction modifier. No help. This thing clunks, skips the tires & has some slight whine/NVH when driving. Might sound like I'm being picky, but just trying to find a better solution. Here in the states, it's impossible to find a Stagea rear diff. No luck. I do have a 300zx non-turbo diff. Same ratio, 5 bolt axles. On the Stagea, you need both front & rear diff ratios to match. This car is a 4.083. I'd like to just swap a normal rear diff into this thing. Nothing fancy. Even open diff is fine. She's not tracking the car LOL The difference is that the ATTESA pump mounts to the top of the rear diff. There are 3 total mounting points for the pump on top of the diff. With all this being said, what would be the best way to go about this? I could remove the Stagea diff & see if I could get somebody to possibly weld the 3 tabs/mounting points onto the 300zx diff so we could mount the pump on the 300zx diff. I could swap the internals from the 300zx into the Stagea diff but this is not in my comfort zone. Is it possible to mount the ATTESA pump to the underside of the car? Sorry for the paragraph. Just trying to figure out how to go about this. Any help is much appreciated! Stagea Differential - Note two top tabs, one bolt hole for ATTESA pump mounting   300zx Diff - No mounting tabs Also found this mounting kit ?? https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • Not ready yet, but maybe later in the year?
